not fully starting or running
I'm about one month and one tank of gas past a carb rebuild. When I try to start her up, she runs just enough to burn up the fuel in the bowl (about 2 engine revolutions) and she dies right out before the crank stops spinning. If I use ether, I can keep her running for a bit longer, and she may even run for 5 minutes off a single shot.
There are no major vacumme leaks, the timing is dead on, the float in the carb isn't stuck (if I remove the screw, there is no gas spill till I rock the truck), and I'm running a new fuel filter. Plugs & wires are less then two years old. The tank was at (or near) empty when I first noticed the problem. and it came after a full throttle take off. She was running perfectly before this.
I'm stuck for an answer, and any help is greatly appreciated.
87 full size Bronco, 351w, Holly 4160 (80457-2)
Last edited by beermonger; 08-05-2011 at 03:32 AM. Reason: global cooling prevention
BossFan
19
08-20-2011 06:59 PM
ghunt
General Automotive Discussion
11-06-2008 09:52 AM
rebel_ford4x4
10-24-2005 10:57 AM
