proportioning valve - Ford Truck Enthusiasts Forums
proportioning valve
Old 08-05-2011, 01:21 AM
arrowheadfred's Avatar
arrowheadfred arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
proportioning valve
The under frame disk/disk booster i have should have a built in proportioning valve BUT i'm not so sure . Even if it has one built in would it hurt to add a adjustabe one ? If so what brand should i get ?
Old 08-05-2011, 12:28 PM
ZOOT's Avatar
ZOOT ZOOT is offline
ZOOT has a good reputation on FTE.ZOOT has a good reputation on FTE.
Is your brake system completed now? Can you drive the truck? If so, the test would be to hit the brakes and see if the disc brakes on the front are working before the rears. Try it in an open parking lot because if the booster doesn't have the proportioning valve, the rear end will start to slide to one side because the rear brakes are not working. An adjustable proportioning valve is needed. Speedway sells them. They sell quality products so I would trust them. Summit sells them as well as many other suppliers. Just don't buy an off brand. The valve on booster ( if there is one ) is preset so adding another one will change the pressure ratio. Hope that helps.
Old 08-05-2011, 10:36 PM
mytbtruck's Avatar
mytbtruck mytbtruck is offline
mytbtruck is starting off with a positive reputation.
Quote:
I am using an adjustable proportioning valve from Summit. It is made by Stainless Steel Brake Co. I have front disc and rear drum brakes. I works very well and I am satisfied with it
Old 08-05-2011, 10:49 PM
Thanks guys !!! I have new everything on my truck but i can't power brake it cause it just won't hold it back and with 4 wheel disk you would think it would .So something ain't right. I have good brakes but they could be better.
Old 08-06-2011, 11:15 AM
ZOOT's Avatar
Sorry for being stupid but what does "I can't power brake it because it won't hold it back" mean ? Should be same pressure to all corners if it's all discs. Maybe I'm wrong,(not the first time)but the whole idea of a proportioning valve is to balance difference in pressure needed for a drums in the rear and discs up front. I can't see what purpose a proportioning valve would have in a four disc set up. It should stop on a dime with four discs.
Old 08-06-2011, 02:07 PM
Lakotas53's Avatar
Lakotas53 Lakotas53 is offline
Lakotas53 is starting off with a positive reputation.
LOL power braking is you keep the front brakes locked while you break the rear ones loose for some really great smoking burnouts!
Which proportioning valve to use? RalphXL Brakes, Steering, Suspension, Tires, & Wheels 0 07-13-2016 10:03 PM
1966 F100 Disk Brake Upgrade Broomfieldbum 1961 - 1966 F-100 & Larger F-Series Trucks 8 10-22-2015 08:46 PM
49 disk brake frustration rbtom 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-19-2015 11:23 AM
front disk brake conversion jerry73 1973 - 1979 F-100 & Larger F-Series Trucks 34 11-16-2012 01:49 AM
Front disk brakes, on 1974 F100 4x4 Dan-79F350 1973 - 1979 F-100 & Larger F-Series Trucks 5 05-17-2000 04:19 PM
Tags
1997, 1st, block, bronco, combination, early, escape, expedition, explorer, f100, ford, gen, proportional, proportioning, repair, valve, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
