4.6 interchange - Ford Truck Enthusiasts Forums
4.6 interchange
Old 08-04-2011, 09:05 PM
Shovelhead 93's Avatar
Shovelhead 93 Shovelhead 93 is offline
Shovelhead 93 is starting off with a positive reputation.
4.6 interchange
Will a 4.6 from a 94 grand marquis fit into a 98 f-150.
Old 08-05-2011, 08:25 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Quote:
You'll need to change out all of the external dress items, but yes, as far as physically bolting in, it will fit. It'll be down on a power a little bit-the F4AE NPI heads on the '95 models are the worst modular 2V heads that were ever made, and are terribly restrictive. The F5AE NPI heads used on the '96-'99 models are far better.
JL
Old 08-05-2011, 09:54 AM
Thanks, what about a newer 4.6, would that be an easy swap or would it be best to stick to 96-99,.
Old 08-05-2011, 10:00 AM
'96-'99 would be the easiest. But, you have to be careful of some of the '99 4.6L's-the Mustang got PI heads in '99,so the intake from your truck won't match the ports on the PI heads, and the car intake won't match anything on your truck.. You could get a PI head 2001-2007 4.6L 2V from an F150 or an Econoline complete with intake manifold and swap it in. You would get a slight power gain that way, although there will be some swapping of parts between your stock engine and the replacement for everything to match perfectly.
JL
Old 08-05-2011, 11:22 AM
Ok, thanks alot.
Old 07-27-2015, 06:07 PM
jfroux_1 jfroux_1 is offline
jfroux_1 is starting off with a positive reputation.
Swap Grand marquis in F150
I wasn't able to start a new thread, the system asked me to wait 5 days (new member). Can you help me?
Iím planning to swap a 4.6L and 4r75e from a Grand Marquis 2006 in a F150 4x4. Iím about to buy a F150 2006 that needs an engine. Anyone did that? Can you help me? I just had an accident with the car, the mechanic is very good.
Is it difficult to swap the transfer case tail from the 4r70w to the 4r75r?
Old 07-27-2015, 07:02 PM
brokenleg brokenleg is offline
brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.
97 and 98 trucks could have either a Romeo OR a Windsor 4.6. and there is quite a few differences. if your truck has the Windsor 4.6, it will have the 8 bolt crank. the Romeo has 6. most cars have Romeos. I went through this. best thing to do is get an engine out of the same year truck as yours. I ended up getting a complete 4.6 for my truck as someone else tried to put a car Romeo engine in it. it was missing a lot of parts and I didn't have all of it. and my truck is a stick which I found out about the crankshaft bolt pattern.
Old 07-27-2015, 07:05 PM
probably will have to rebuild the tranny to fit it up to the transfer case.
what engine is in the truck? I would bet its going to be more trouble than its worth.
any problems with the 4.6 triton ??? JF5speed Modular V8 (4.6L, 5.4L) 25 04-26-2016 09:00 AM
Last generation kenny nunez Explorer, Sport Trac, Mountaineer & Aviator 5 04-21-2015 07:59 PM
4.6 engine jdsgtball Modular V8 (4.6L, 5.4L) 0 04-08-2015 10:49 PM
4.6 liter questions My98FordF150 Modular V8 (4.6L, 5.4L) 49 08-04-2014 09:45 AM
4.6 engine swap mikepink 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-22-2000 07:32 PM
Tags
1997, 2001, 46, 46l, explorer, f150, ford, gt, heads, interchange, interchangeability, mustang, physically, soc, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordģ is a registered trademark of the Ford Motor Company.
