99 f150 major electrical issues please help!
I recently purchased a 99 f150 with 196k on it and it had rearended a trailer and the guy I bought it from says everything still working fine until he had it on a 200 amp quick charge too long and now the truck runs rough, wipers don't work, dome light don't work, 4x4 doesn't light up or engage, power Windows and a couple of other miscellaneous things any advice on what I should check?
All those circuits are controlled by the GEM module.
We still got some people who think they are working on a farm tractor or an old time truck to put 200 amps to it and go leave it without a timer on the charger. Lucky if the battery is still worthwhile.
The charger likely took the system voltage to high. The GEM is always alive, key on or off.
Good luck.
Good luck.
