Replacing TPS Fixed My E40D Shifting Issues
Old 08-04-2011, 02:24 PM
Brad Felmey's Avatar
Brad Felmey
Brad Felmey is offline
My 1994 F150 5.0/E40D with 215,000 miles was shifting poorly; sometimes upshifting too quickly, sometimes refusing to downshift, sometimes downshifting into 2nd on the highway.
After consulting the wealth of information in this forum I purchased the $31.99 Equus Innova 3145 Digital Code Reader from my local O'Reilly Auto and confirmed what I suspected - the computer was receiving faulty readings from the Throttle Position Sensor (code 121, in my case).
I purchased a $22.89 Standard TH44T TPS from Rockauto.com and got to work. This is a non-adjustable type.
It took me about 10-15 minutes to have everything apart and ready to go back together, mostly spent determining which tools I needed and walking to the shop to get them.
I ensured that the connector pins were not corroded and that I properly installed the sensor by inserting about 1/4 counterclockwise and then rotating clockwise to the proper position for the screws. I plugged in the (2) sensors on the throttle body and re-ran the Key-On-Engine-Off (KOEO) test again with the Equus and got a clean bill of health. I then cleared the computer memory and buttoned everything back up in about 5 minutes.
It made a world of difference in the transmission shifting. It now shifts as smooth as you like, it upshifts, it downshifts, it cleans bathroom soap scum.
Below is a picture of the old TPS. I'm going to go out on a limb and say I think I can guess what the issue was.
Old 08-04-2011, 02:53 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
Excellent find, thanks for the feedback!
Old 08-04-2011, 03:06 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Good job on the fix!!!!
Thanks for the report!!
I wish more people would take time to get codes and do the needed repairs before they call the E4OD a piece of crap.. I would bet 75-80% of the E4OD problems have nothing at all to do with the trans..
You just proved that is possible with yours..
Rant off.......
guitar_199
07-24-2008 04:55 AM
Chad Winship
1978 - 1996 Big Bronco
07-12-2008 07:41 AM
aeomholt
05-09-2008 09:25 AM
snubber
30
01-31-2008 11:21 AM
Jrock909
12-12-2004 07:52 AM
Quick Reply: Replacing TPS Fixed My E40D Shifting Issues
