Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Tennessee Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Tennessee Chapter Join Chapter Leader: Neal 97 250
  #1 (permalink)
Old 08-04-2011, 01:05 PM
TNScrambler's Avatar
TNScrambler TNScrambler is offline
Garage is empty, add now
TNScrambler is starting off with a positive reputation.
Interrior Re-do
I posted this over in the Diesel '94-97 forum, but figured its not really diesel specific so I thought I'd show yall what I did to dress up my interior some, since the truck is paid for and while I'd love to have a new one, I don't need a new one, so I did this to at least make it more comfortable and update it some...
I finally got around to put these in this weekend. The rear is just a matter of positioning it where you want and drilling new holes and bolting it in. I pushed mine as far back as they would go and didn't seem to loose any room over stock in the rear. The front seats I used the factory SD power bases as I had my stock seats sold already and couldn't rob the manual slider bracket....but it turned out to be so easy it worked out great.
The front I sat in there where I thought I wanted them, hooked up the power so i could play with the adjustments and make sure, then marked and drilled my front holes. The driver side didn't need any mods to the brackets at all, I drilled two new holes for the front brackets, in the rear there was a sheet metal body cross member underneath where I wanted to put the holes, so I just cut a piece of angle iron and clearanced it for the movement of the tracks, drilled a hole in it for the original rear mounting stud and used it to retain the rear seat mounts. On the passenger side it was almost as easy but I did have to bend the front left (closest to the trans tunnel) bracket. Drilled the front two holes, did the same angle iron for the rear mount. Used the factory SD plugs and wired into the OBS powerlumbar circuit.
The seats work great, I gave myself a little more leg room up front, but there is plenty of forward travel to give rear passengers more leg room if needed....but 95% no one rides behind me. Also I love the fold out rear load deck, I have already used it and it is NICE. The seats are way more comfortable, however they do sit higher, even with the bases lowered all the way.... I'm 6'2" and my wife says i have a long Torso, but I fit just fine. But if your taller or have a longer torso, you may have to do more mods to the seat brackets to lower them. But like I said it was so easy I think it would have taken longer to remove the factory bracket and re-drill the wholes for these seats.
For some reason not all the pics are showing up, so here is the link to them.... F250 crew cab pictures from trucks photos on webshots
Click the image to open in full size.
__________________
1996 F250 Crew Cab Short Bed 4x4.... D60, Hard Knox RSK with SD front and rear springs, 6637, 3in. downpipe, 4in. exhaust, E40D (ZF-6speed coming soon), '07 SD Lariat Seats, 140v IDM, hydroboost brakes, 38 gallon rear tank, and 251k +
www.efienginesupply.com
  #2 (permalink)
Old 08-05-2011, 10:49 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
Thanks for postig this. If you need any interior pieces I parted out a '97 single cab. Have all of the plastic trim still minus one or two pieces.
__________________
97 F250 Rosewood Stage II.75's, DP Tuner Live Tuned, Modded H2E, Terminated HPOS, Comp 910's, ARP studs, Swamps Pushrods, 6.oh Cooler, BDP elec. reg. return fuel, Valair full feramic clutch, RSK, D60, SD 1 ton springs DRD INMATE # 40
Neal's Pics and H2E install
Tennessee Chapter Leader Join Chapter here
  #3 (permalink)
Old 08-05-2011, 11:54 AM
Quote:
Do you have the a-pillar trim on the driver side? Mine is cracked through the mounting screw hole beside the dash. I have previously found and replaced the black plastic trim around the speedo and headlamp switch etc as mine was cracked on the mounting hole. I also previously found and replaced the dash pad that goes above the radio and over the glove box with a nice un-cracked unit.
I still need to do carpet and headliner, I found a carpet kit through rock auto that you can buy extra mass insulation and what not, so I plan to use that, but want to wait till after the trans swap so I know where to cut for the shifter etc..
Justin
__________________
  #4 (permalink)
Old 08-05-2011, 02:36 PM
macgiobuin's Avatar
macgiobuin macgiobuin is offline
1966 Ford F-100
macgiobuin has a great reputation on FTE.macgiobuin has a great reputation on FTE.macgiobuin has a great reputation on FTE.macgiobuin has a great reputation on FTE.
Looks great!
  #5 (permalink)
Old 08-07-2011, 12:26 AM
jdecker88's Avatar
jdecker88 jdecker88 is offline
jdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to behold
Great job man, I know it was one of the best mods I did to my truck adding the fold out cargo deck.
__________________
Justin (JD)
2000 F-250 CC SB 4x4
Roadside Help NetworkDP-Tuner Guzzle's Truck Site
Pete's Custom Filter Covers Riffraff Diesel Performance
Quote:
Originally Posted by megawatt00 View Post
Kinda tough to embrace the dark side when your an electrician.
  #6 (permalink)
Old 08-08-2011, 07:00 AM
Justin
A- pillar and the piece under the wheel with the pocket are the only two pieces I don't have.
Where in the world did you find a dash pad that wasn't cracked?
__________________
  #7 (permalink)
Old 08-09-2011, 10:02 AM
I found a guy locally that was parting out a wrecked truck on craigslist, it was high mileage when wrecked, but he had bought it two years previous with only 89k on it and he seemed pretty meticulas on cleaning and what not....believe it or not, my truck with over 200k on it when I bought it had a clean un cracked one till I hauled a TV in the front seat and accidentally let it smack the dash
Justin
__________________
Tags
78, bronco, interrior, parts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
