F250 front end sag
F250 front end sag
I have a 1996 F250 4X4 and am concerned about the front end sag. The truck lists slightly to one side. The rubber stops are 1 finger width or less from the leaf springs, and actually touch the springs when plow is on (8ft Fisher). My initial plan was to replace the springs - truck is almost 16 years old with 100K. One shop told me that new springs wouldn't be enough and I should add a third leaf. Next shop said can't run 3 leaves on 250 but new springs will help. Another said skip new springs and go with Timbrens or Air bags.
The truck is regular cab w/ 460 - front spring code is 9 (3485 lb springs I'm told)
Anyone have any experience or ideas on this? Any help much appreciated.
My uncle had a 95 w/ the leaves up front, but he had a crew cab, so there's more weight. Anyways, his had gotten so weak that when he turned into his driveway the slope and the turn would just kill his springs and his tires would rub on everything. So they definitely wear out. He just new springs up front and that solved his problem.
The shop that told you, you can't put more than 2 leafs on an F250 is most likely because they didn't want you to be in there for an alignment to adjust camber with more springs.
Heres a 1991 F250 Diesel with 2 add a leafs up front..... and Harsh ride ain't even the word for that one..... whew!
Wow...I bet! I bet new springs would really help, and maybe if you still have a problem a drop shackle of some sort? Idk...the thing that scares me about air systems (no offense airlift guy) is that they're a little delicate. I mean, everything else under there is metal for a reason. And all it takes is one little hole in a bag to ruin your day. Like the ol man always said, "When in doubt, make it stout!"
Mine are sagging a little too. I was at the dealership one day for something else and decided to ask about new leafs. The guy asked me if I ran a plow because Ford has a code for those heavier springs as well. I'm not looking at a lift or anything so I may just go with new leafs and call it done, although I think I can find a better price than the dealer.
One thing I wonder, though. How long does it take the new leafs to settle down to the point where you're not getting an alignment every six months?
I would certainly like to think so. Course, I'm biased because my truck is essentially the same age as myself So I'm pretty impressed that it's still going strong when my friends have newer model cars and trucks that are having the similar, if not worse problems. And the fact that It's way better looking and tougher is the icing on the cake!
