I wanna tach!
Um...what do you mean you know where the gauges should be? I'm not sure about the temp, but the oil pressure gauge runs off a switch. It will read anywhere in the 'normal' range as long as there is 7PSI! You can't possibly know what is going on with the stock oil pressure gauge. Compared to that the gas gauge is a precision instrument
JIM.
Yeah, 60 is about right at start up, but after the oil heats up some the pressure will drop and rise with the engine speed. Like if you come off the highway it could go to 40psi at a stop sign and then back up to 55 on a gravel road. A real gauge would've been moving for changes like that. the scary part is how low the pressure has to be for the switch to turn over. So you could be doing 70 on the highway with a trailer on and thinking everything is hunky-dory and suddenly have your check engine light on and your oil pressure gauge pegged on the low side. and who knows what's happening to your engine. this is the stuff nightmares are made of
And i'm just not too hot on the true mechanical gauges. Oil in the cab would suck, as it would anywhere under the hood where it shouldn't be. I figure that a modern electronic sensor will be pretty darn close to accurate, and ANYTHING is better than stock.
tomtoc
18
05-01-2007 07:00 AM
DrewV
03-29-2005 09:46 PM
Holmesuser01
12-02-2004 07:55 AM
