3.9L (Freestar) Intake Manifold Runner Control - Ford Truck Enthusiasts Forums
Old 08-03-2011, 10:51 PM
99expyTN 99expyTN is offline
99expyTN is starting off with a positive reputation.
I realize this is mostly trucks, but I thought someone might benefit from IMRC problem. My 2004 Freestar threw code P2004 - Intake Manifold Runner Control stuck open - bank 1. After a little research via google I found a diagram of the IRMC and then found it on my freestar. Below is a picture of the condition it was in:
The bushing was broke. I purchased a new pack of bushings from Advance Auto (dorman 47099, pack of 5, $2.50). I dropped 2 before I managed to get one in the lever. The trick - I wrapped my finger with duct tape, sticky side out, and then stuck a bushing on it. I could just get my finger down there to push the bushing in the lever. I then used needle nose pliers to push the rod into the bushing.
Anyway, maybe this might be helpful to others.
Old 08-05-2011, 01:21 AM
bokker bokker is offline
bokker is starting off with a positive reputation.
pictures paint a thousand words! bokker.
Old 08-05-2011, 09:30 AM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
+1 ^
Thanks for sharing.
Old 06-19-2012, 02:03 PM
SeabeeO(Ret) SeabeeO(Ret) is offline
SeabeeO(Ret) is starting off with a positive reputation.
Thanks!
The dealer wanted $350 to replace this IMRC clip. Ever other internet post says clips are available only from a dealer. I called Pep Boys and Advanced Auto and they said the same. It looks like to me that Dorman 47099 bushing you used will work perfectly. I'm currious to know if the bushing has been holding up for you.
Old 08-25-2013, 09:43 PM
Never saw this question from 2012, but just to follow-up.......the Dorman bushing is holding up just fine. I replaced it 2 years ago at 94k miles and no problems. Now at 118k miles on odometer
Old 08-18-2014, 01:45 AM
whodeylt whodeylt is offline
whodeylt is starting off with a positive reputation.
does anyone know where the imrc is located on the engine of a 2005 freestar? im getting a code p2006. the pic at the top of this post is an excellent picture but im not sure exactly where it is on engine. thanks
Old 05-14-2016, 03:11 AM
spiralthomas spiralthomas is offline
spiralthomas is starting off with a positive reputation.
IMRC location 05 freestar
[QUOTE=whodeylt;14591852]does anyone know where the imrc is located on the engine of a 2005 freestar? im getting a code p2006. the pic at the top of this post is an excellent picture but im not sure exactly where it is on engine.
it's right in front of the fuel rail on the front of the motor. had a wicked combo of issues, turned out the IMRC bushings/nylon nuts were the real culprits. got some dorman 47099s on the way, hopefully she will be all better. good luck
any way to activate IRMC valve without engine running? ojai150 2004 - 2008 F150 3 10-23-2015 12:59 AM
2004 Freestar P0193 OBD 11 code JACKUS2 3.8 & 4.2L V6 0 12-05-2011 10:25 AM
Freestar code p2004 mitymerc Escape & Escape Hybrid 1 06-13-2010 10:53 AM
IRMC accuators BlueOvalFitter 1997 - 2003 F150 0 07-01-2006 09:51 AM
Freestar 4.2 L V6 with a RWD tranny? shelessj Engine Swaps 7 07-05-2005 06:37 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2004, 2005, bank, control, ford, free, freestar, intake, manifold, ontake, open, p2004, runner, star, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
