6.2L V8 Discuss the 6.2L V8
I hate my heater!!!
Old 08-03-2011, 06:04 PM
love4x4's Avatar
love4x4
love4x4 is offline
I hate my heater!!!
I did not want this Laramie with all the fancy junk but it is all they had without ordering an SLT and I couldn't wait!!!
Climate control my aching butt!!!
Scenario: 20 degrees outside. Get in truck and drive away. Set heat at 70 degrees. Get on freeway, destination, 20 miles down the road. 70 degrees is reached in cab. BANG!!!! AC comes on and blasts ice cold air through the dash vents and NEVER STOPS!!!!
I have resigned to run the heat as manually as possible. Crank it up till it gets too hot then turn it off. Repeat!!!
Dealer contacted Ford and they said it is doing what it is supposed to. Great job Ford!!!!
Old 08-03-2011, 07:52 PM
boomsling's Avatar
boomsling
boomsling is offline
Uhh, I think Laramie is dodge....or am I missing something here?
Old 08-03-2011, 08:38 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
I've never had that issue with my climate control, but then again, I got the Lariat.
Seriously though, it's getting up to that temp and then the A/C kicks on? I never had that issue once last winter here in PA. Take it back to the dealer, if they say it's working correctly, try another dealer. That's definitely not functioning as designed. If you continue to have issues, there's a Ford customer service rep over at thedieselstop.com (Cory) that's been very helpful for the folks over there. Might be worth signing up to pm him your issue (which he's capable of escalating from what I've seen).
Old 08-03-2011, 08:43 PM
love4x4's Avatar
love4x4
love4x4 is offline
Crap!! Sorry. EX Dodge guy!!! Yes it is a LARIAT!!!!
Old 08-04-2011, 07:48 AM
kmonty2's Avatar
kmonty2
kmonty2 is offline
Could it be that it is trying to keep the cab at 70 no matter what needs to be on, heat or AC? I don't have that fancy climate control on my truck just the standard on/off and red/blue temp control.
Old 08-04-2011, 08:43 AM
2000silverbullet
I could understand if it turned cold for a brief period to maintain the temperature, but love4x4 said the cold never turns off.
Old 08-04-2011, 09:02 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
i never use the auto mode...i just manualy set the temp/fan speed. normally its either on 90 and high or 60 and a/c on high lol...i go extreme!
Old 08-04-2011, 10:23 AM
Super08's Avatar
Super08
Super08 is offline
If it is acting as he explained it needs to be looked at. I just set the temp in mine and leave it in auto. It functions flawlessly.
Old 08-05-2011, 08:04 AM
kmonty2's Avatar
kmonty2
kmonty2 is offline
i see your point, yeah it should just be for a short period and not stay on.
Old 08-10-2011, 12:32 AM
socapots's Avatar
socapots
socapots is offline
mine is like this as well.
it will actually even slow the fan speed down as it approaches whatever temp i set it at.
You should be able to mimic that when the cab i hot (say when you first get in it). turn the AC on auto. and then adjust the temp up bit by bit.. it should get to the point where you hear the fan slow down.
as to why your truck would turn the AC on when you are trying to heat i dunno.. unless you got the dual climate activated and the 2 sides are trying to fight each other.. if thats even possible..
and another idea.. instead of turning the heat on until its to hot then turning it off.
why not put the heat on. and when it gets to an acceptable temp just turn the temp setting down a touch.. or even the fan speed.
Old 08-10-2011, 09:16 AM
DirtEngineer's Avatar
DirtEngineer
DirtEngineer is offline
I know from my previous '08 Expedition with Auto Climate Control that the dual zone will "fight" eachother. I like the truck cooler, wife likes it warmer. On the Expy, she'd have her side turned up to 23C, while mine was at 19C. A/C would come on, sending cool air my way, and warmed, air conditioned air her way.
I know with both my Expy and my F250 now, the climate control works great. I set the temp I want, and that's it. Truck does the rest. In the mornings, I get heat, in the afternoons I get A/C. The only time I ever intervene in the climate control is if I need some defrost action, and even then, it's just a push of a button to get the wind blowing to the windshield.
ISPF150
1997 - 2003 F150
34
10-06-2013 07:27 PM
mohle
1999 to 2016 Super Duty
11-11-2010 08:47 PM
jyblood
01-24-2008 07:17 AM
F250Moneypit
02-10-2007 06:11 PM
swinters
1983 - 2012 Ranger & B-Series
03-24-2002 12:41 PM
Quick Reply: I hate my heater!!!
