help! need more power
I have a 96 bronco with maf 351w. I run dana 60s front and rear with 37s. looking for a head/cam setup that will give me more power, nothing too crazy but stock numbers suck. the truck is mostly a toy but i would like the keep it a friendly driver. any suggestions would be much appreciated. trying to keep price around 2g.
on
What gears are in the axles? No matter what you do to the motor the truck needs 4.10-4.56 gears period.
As for an engine hop-up combo, anything from the AFR165/185 to RHS 180s to TFS 170s or anything else in that range will work great... though you'll need a better intake to take full advantage(Edelbrock Performer or ProProducts Typhoon). And for a cam I'd suggest the Comp 35 320-8 advanced a couple degrees from straight up. This combo will make 400tq and 350hp no problem at all.
amenjephra1
07-27-2003 11:23 PM
