Brake upgrade? - Ford Truck Enthusiasts Forums
Brake upgrade?
Old 08-03-2011, 12:02 PM
SCRWDRVR's Avatar
SCRWDRVR SCRWDRVR is offline
"Obsessed"
SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.
Brake upgrade?
I need front brakes so I'm looking into going with drilled and slotted rotors and ceramic pads. I dont mind spending the extra for it but my money is limited, what do you guys recommend for a guy on a low budget?
Old 08-03-2011, 12:10 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
4 Wheel Parts and Summit Racing carry the "PowerStop" brand in kits. They're pretty inexpensive, being about $225 or so per axle. That's rotors and pads for both sides. I've seen guys here using them, but I'm still not 100% sold. Those are slotted and drilled rotors, with PowerStop's ceramic pads.
I'm due brakes this month too, and I'm leaning towards Wagner rotors and Thermoquiet pads, or EBC rotors and GreenStuff pads.
Old 08-03-2011, 03:42 PM
CaptFX4 CaptFX4 is offline
CaptFX4 is gaining momentum as a positive member of FTE.
I'm not sure if there are huge benefits to the drilled / slotted rotors either.
Last year I replaced my rotors with Napa Premium rotors and put Hawk brake pads on. Better stopping power than stock and almost no brake dust.
I was thinking or ceramic, but was told they chew through rotors quick.
Just my opinion.
Old 08-03-2011, 07:34 PM
SCRWDRVR's Avatar
"Obsessed"
Thanks guys, maybe I'll do just that CaptFX4 I'm not real hard on brakes so that will probably be the way to go...
Old 08-03-2011, 07:37 PM
MCDavis's Avatar
I had good luck with my Explorer and NAPA's Ceramix pads. They were quiet, gave off almost no dust, but they were a little more abrasive than a semi-metallic pad. Under real light braking, especially when cold, you could feel them initially.
Old 08-03-2011, 07:50 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
2 Front Precision Drilled Slotted Brake Rotors F-150 | eBay
6 months ago i put these rotors and hawk pads on. what a difference in stopping power. i would recommend these to everyone
Old 08-03-2011, 08:37 PM
SCRWDRVR's Avatar
"Obsessed"
Thanks, I take it Hawk is a name brand?
Old 08-03-2011, 08:49 PM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
Just put Autozone $83 each duragold rotors and the ceramic pads on my '04 150 2 wd,...very happy..
Old 08-03-2011, 09:57 PM
tooldad tooldad is offline
tooldad is starting off with a positive reputation.
Put cross drilled PowerStop rotors and Akebono ceramic pads on my F150. Could not be happier with stopping power and no dust. I tow a little and have non-stock tire size.
Put NAPA Ultra Premium rotors and pads (ceramic) on my daughter's 4Runner. Happy with them too. No towing and stock wheel/tire setup.
Either are good.
Old 08-03-2011, 10:24 PM
Either are good.
How are the new spark plugs running?
Old 08-04-2011, 04:22 AM
SCRWDRVR's Avatar
"Obsessed"
Thanks all, looks like a trip to napa is in order...
Old 08-04-2011, 02:07 PM
ojai150,
No problems after plug change. All running wel. Thanks again for the help!
Old 08-04-2011, 03:13 PM
ojai150,
Mine too purrs,..I was concerned as I used Autolites but runs great
Trans overdrive went out suddenly at 101,000 had a lot of wear, so I had a it rebuilt with heavier converter and clutches,,$2500.00
safety issue.....brakes....help anthonym92 1987 - 1996 F150 & Larger F-Series Trucks 53 09-08-2015 02:15 AM
BRAKE PROBLEMS (ALL DRUM BRAKES) SonyResendiz 1961 - 1966 F-100 & Larger F-Series Trucks 17 12-05-2014 09:29 PM
05 brake job. Sticking brakes. Ford'05HG 1997-2006 Expedition & Navigator 7 08-17-2014 02:54 PM
Brake life 351Cleveland C4 1967 - 1972 F-100 & Larger F-Series Trucks 7 03-10-2014 12:26 PM
Brake light on 79'F-250_Guy 1994.5 - 1997 7.3L Power Stroke Diesel 15 02-05-2014 09:26 AM
Tags
2007, brake, brakes, ceramix, duragold, f150, f150s, napa, power, powerstop, reviews, rotors, stopping, upgrade, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
