5.4 TRITON - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
5.4 TRITON
Closed Thread
Old 08-03-2011, 12:42 PM
SALVAGEGUY23 SALVAGEGUY23 is offline
SALVAGEGUY23 is starting off with a positive reputation.
5.4 TRITON
Trying to get some documentation on paper and so far all internet searchs have come up empty. I work at an auto recycler and sold a customer a good running 5.4 motor from an 03 Expedition. He had a backyard mechanic install the engine and according to the Ford dealer where the vehicle is now parked the guy "butchered" the installation as far as wires and hoses going back to where they belong. The customer is taking us to court for selling him a bad motor.
Here is the crux of the problem : The backyard mechanic never did the motor to fire which does not surprise me because if he had cranck/cam sensors wrong or screwed up he could turn it over all day without firing. BUT.... the motor now has two cylinders with no compression. A local mechanic who has done multiple 5.4 installations says that when he bolted up the torque converter and if he turned the flywheel backward with the dual cam heads in this motor a saddle inside would cause the timing chains to be out of sync and bend valves in the heads. His theory is backed up by another trusted Ford dealer's head mechanic. Unfortunately the head mechanic says there probably isn't a Ford TSB or manual detailing this. He says the installation instructions at his dealership all have large warning on them to "follow installation protocol" with regards to this issue and that it is common knowledge taught when a mechanic is certified.
Any help with this from you experienced Ford guys? I really would like to have documentation on paper when we have to go to court. Thanks!
<!-- / message -->
Old 08-03-2011, 05:32 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Since the dealer says the installer butchered the installation, I would think that's enough to allow you to prevail.
As far as the turning the engine backwards and bending valves, well that sounds like a load of bunk. Just imagine how many engines would be trashed over a simple backfire or misfire when trying to start the engine. The fact that it's bunk would also explain the lack of available information on the subject. There's not going to be any documentation if there really isn't an issue.
Old 08-04-2011, 08:32 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Sorry, but this thread is in violation of FTE rules:
"8. Legal Actions.
You may not use this site to discuss or organize any legal action including, but not limited to, class-actions. FTE does not give legal advice or host legal discussion. If you have any legal questions or concerns, please consult your attorney.
You may not create posts or threads which discuss or request by-passing payment of online services including, but not limited to, Carfax reports."
Ford Truck Enthusiasts - Discussion Forum Guidelines
This thread will now be closed.
Closed Thread
7.3 or 5.4? Texas Chain Ring 1999 to 2016 Super Duty 83 04-29-2013 07:19 PM
97 F 350 powerstroke ignition wiring problem dlsweet 1987 - 1996 F150 & Larger F-Series Trucks 0 11-12-2011 09:36 AM
2001 ford ranger 3.0 synco problems jerrygallion 3.0L V6 1 08-26-2011 11:41 PM
5.4 TRITON CRANK DIRECTION SALVAGEGUY23 Performance & General Engine Building 2 08-01-2011 03:50 PM
Towing w/98 F250 V8 5.4L Triton Questions Reneej Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 1 07-08-2011 09:05 PM
Tags
2001, 2003, 54, backwards, bend, bent, flywheel, misfire, specs, synchronize, torque, triton, turn, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
