Tips on removing Exhaust Manifold bolt?? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 08-02-2011, 06:56 PM
jimkari jimkari is offline
jimkari is starting off with a positive reputation.
I have a '97 with the 5.4. I noticed a ticking noise when cold and thought possible exhaust leak. After searching the forum and seeing the number of broken bolt issues, I was even more convinced this was probably my issue. Sure enough the last bolt on the back cylinder, driver's side is broken off clean at the manifold. Also the manifold to exhaust pipe flange bolts are almost completely rusted away. Any tips on removing the broken bolt? I'm thinking I probably need to remove the whole manifold to get the old bolt out and address the flange bolts, but I hate to risk breaking more bolts off in the head.
Thanks,
Jim
Old 08-02-2011, 09:02 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Your best bet is to remove the whole manifold and replace all studs, bolts, and nuts. Fortunately the studs holding the manifold on will back out fairly easy, even if you break them. Once the manifold is removed, more often than not you can turn the studs out by hand.
Remove both the driver's front wheel and the wheel well skirt to open the area up. It's not as bad of a job as it might appear.
Old 08-02-2011, 10:07 PM
Thanks for the tips. I think you are correct. I tired welding a nut onto the stud, but so far I haven't been able to get any real strong weld onto the stud. It does look like there is a fair amount of room with the wheel and fender flap removed.
Jim
Old 08-02-2011, 10:51 PM
fordno1's Avatar
fordno1 fordno1 is offline
fordno1 is starting off with a positive reputation.
My Luck
I guess I am one of those that the "turn the remainder of the bolt out by hand" didn't work. It really was a PITA and I was doing passenger side. I had 3 bolts break off. 2 broke off flush with the head and the other one stuck out about 1/2 inch. Guess which one wouldn't back out and which ones did? You got it, the two that were broke off flush with the head I was able to get out with an easy out after drilling. Oh yeah, I had to drive 60 miles to buy one of the right angle air drills to get those 3 bolts out. What a day that was. Yeah, then there was that one that had 1/2 inch sticking out. Well, the easy out broke, eventually got the piece out. Then drilled a bigger hole. The next easy out wasn't going to remove it either. So drill it out so I could rethread it. I drilled the right size for an 8mm 1.25 thread and wouldn't you know it, the little sliver pieces started coming out. I didn't damage the threads in the head and was able to thread the stud into it without problems. Time into at this point - 4 hours and that is without the 2 1/2 round trip time spent buying the drill. No one had it closer and it was worth the drive to buy and Ingersol Rand right angle drill brand spanken new on sale for 50% off retail. Finally, ready to reassemble. Well, maybe I should have looked at the exhaust manifold a little more closely. It wasn't going to work. The surfaces were too corroded so off to NAPA and order one. Why don't they stock these I will never know. Pick up the next am(Saturday). Used all Ford gaskets, studs and nuts and it went back together fairly well. No leaks. I can't imagine doing the drivers side. It was a little difficult with the rear heat & a/c lines in the way. Can't imagine the steering and that EGR pipe to remove. Just so the drivers side doesn't start ticking. Oh, then there was the steering and suspension parts that were replaced because the wheel shouldn't move like that when you start torquing the lug nuts by hand. Tie rod later it's better and then those upper control arms/ball joints were bad. What's another trip up to NAPA right. All said and done, this job cost me $600 with parts and that drill. Sorry, forgot to mention the battery light came on when I started it when I was all done to check for leaks. No way, it was fine 2 days ago. Alternator crapped out just sitting. This was supposed to be a manifold replacement but ended up being a lot more. I checked the whole truck over 2 months ago before I left on 2500 mile trip. Everything was tight. Those parts wore fast once they started. So my advice is as long as you are into it and working on it, give everything a good once over. Check the upper/lower ball joints, tie rod ends and that idler arm on the right side frame. Never know, maybe the battery light will come on and you will have to replace the alternator too.
Old 08-03-2011, 12:49 AM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
fordno1, I'm glad you found all that in your driveway. It would be a very bad day if it happend a thousand miles from home.
Old 08-04-2011, 06:31 AM
Thanks for the thoughts. You definitely made me think twice about my slight exhaust leak. I am probably going to let it sit for a little while longer. Maybe tackle it in the fall.
Jim
Old 08-04-2011, 10:25 AM
Why are you waiting? The exhaust leak will eat away at the surface of the exhaust port in the head. Then when you go and fix it the exhaust gasket will not seal and the only solution will be to replace the head.
Old 08-04-2011, 01:25 PM
Moto Mel's Avatar
Quote:
Agreed, that is a real possibility if the leak is in the area of the manifold to head mating area. The headaches you are facing now are small compared to a head replacement. Just finish the job and be done with it. A nice thing about working with an aluminum head is that they are not too difficult to repair. If you do wallow out the hole you can just install a Helicoil or re-tap it to a larger size and get on with your life. GIT 'ER DONE!!
Old 02-04-2013, 09:20 PM
turp turp is offline
turp is starting off with a positive reputation.
hi gentlemen , just went through the same thing on a 7.3 diesel, two bolts broke off flush with the head. had to drill them out. my question is on one of the holes I used a slight to big of bit!!! after retapping, the bolt is a little loose, have about half of the thread depth it should have. can I go to the next size tap and recut and use a 7/16 bolt instead of the 3/8 ??? the holes in the manifold will allow the larger bolt. (cast iron heads)
Old 02-05-2013, 12:15 PM
Quote:
I think you will have just enough space to get the bolt through. But if not, you can run a 7/16 bit through that one manifold bolt hole to make it fit.
Old 02-05-2013, 05:28 PM
I will not hurt the integrity of the head if I drill out and tap to 7/16 hole will I ? the hole is the farthest rear on the driver side not a lot of mass around this port on the head.
Old 02-06-2013, 09:39 AM
The difference between 3/8 and 7/16 is 1/16 in diameter or 1/32 off each side of the bolt hole. To give you an idea of how small the difference is, an average toothpick is 1/16 in diameter. So you'd be taking half the diameter of a toothpick off each side of the hole. With that image in your head, take another look at the bolt hole and you should be able to visualize if there is enough material to drill the larger hole.
FIXED Ford 4.9 300 cid Exhaust Manifold Leak at Head FIXED Econoline Bronco REMFLEX GASKET cordts 1968-2013 Full Size Vans 8 06-28-2015 05:33 PM
Broken Exhaust Manifold Bolt RedBandit 1987 - 1996 F150 & Larger F-Series Trucks 17 09-14-2014 10:31 PM
broken exhaust manifold bolt removal beckman 1997 - 2003 F150 2 02-15-2013 01:10 PM
broken bolt at the downpipe on the exhaust manifold powersmoked Ranger & B-Series 6 04-16-2012 03:27 PM
460 Manifold bolt length ArdB Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 02-07-2010 07:44 PM
Tags
94, bolts, computer, damage, electonrics, exhaust, f150, ford, manifold, nut, removing, stud, taking, tips, weld
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
