how to adjust the e-brake? - Ford Truck Enthusiasts Forums
Old 08-02-2011, 04:57 PM
bigunit54's Avatar
bigunit54 bigunit54 is offline
bigunit54 is gaining momentum as a positive member of FTE.bigunit54 is gaining momentum as a positive member of FTE.
Hi guys,
I am getting ready to put new rear rotors on my truck, probably in a couple of weeks. I have been told that when I do the job that I should adjust the e-brake. my question is, How do you adjust the e-brake exactly and is it adjusted on both rear wheels or just one? Thanks guys.
Old 08-02-2011, 09:24 PM
2002sport 2002sport is offline
2002sport is starting off with a positive reputation.
It adjusted on both rear wheels. There is a rubber plug with a star wheel inside you rotate with a flat screw driver or a brake adjuster tool. It's not very accessible, but can be done. I went to back mine off a couple weeks ago. Put the rubber plug in the left side, and it went all the way in. I had to take the drum off to get it out, good thing though, cause both linings were laying in there inside the drum. I put new linings on both sides, truck is no longer sluggish, I guess they were putting a drag on there most of the time when they'd get caught in there together. When I put the new ones on, I left them backed off most of the way. I don't use them, but they will still hold if I need them. They were still almost in contact with the drum when they were all the way loose. What I mean, I had to work the drums some to get them over the linings when they were all the way backed off. Probably could have tightened them a bit, but as I said, I never use it so I left them alone.
Old 08-02-2011, 09:49 PM
BoydGilley BoydGilley is offline
BoydGilley is starting off with a positive reputation.
The factory manual shows 1 wheel but i'd say that both wheels will need to be adjusted, check them to be sure.
Old 08-02-2011, 11:00 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Just pull the rotor off and adjust and inspect the tiny brake shoes I use a drum brake gauge and set them for 1/8'' less than the diameter of the internal drum.
Old 08-03-2011, 05:23 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
Most drum brakes are self adjusting. Ours are actually "parking" brakes, and are only (usually) engaged manually at a stop. That star wheel is for getting the shoe adjustment close to correct (and for backing the shoes of for hub removal). The way we would complete the adjustment on the old drum brakes was to roll slowly backwards and apply the brakes firmly. That would cause the shoes to seat properly and you were done. All of us old guys can remember the excitement after going through water and trying to stop with all drum brakes.
I've heard of several people having the drum/parking brakes on our model truck siezing. Likely from lack of use, same as 4x4 shift motors seldom being used.
how to adjust e brake Pastor Scott 1999 to 2016 Super Duty 0 02-03-2017 09:01 PM
E-brake adjustment on 2010 Navigator bbusbee57 2007 - 2014 Expedition & Navigator 1 10-05-2016 02:55 PM
E-brake adjustment benthere 1999 - 2003 7.3L Power Stroke Diesel 2 02-13-2011 05:20 PM
E-brake cable adjustment JHoffman93 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 12-23-2009 09:19 PM
emergency brake adjustment hasbeen Explorer, Sport Trac, Mountaineer & Aviator 3 09-19-2003 08:54 AM
Tags
150, 2004, 2006, 2007, 97, adjust, adjusting, brake, brakes, ebrake, escape, f150, f250, ford, tighten
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
