Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
'77 F250 4x4 build
Old 09-02-2011, 07:43 PM
Feets's Avatar
Feets
Feets is offline
'77 F250 4x4 build
I wanted to call this thread "building a truck out of junk nobody wants" but I thought I better keep it simple/ easy to understand.
I have always liked the old ford trucks, I wanted a 4x4 to work on and take on some of the moutain trails around here. I have built and swaped engines in the past, and i have some fabrication experience. I really wanted to do a frame off build up. Overhual everything, paint it, build it strong.
What I have is a 77 f250 4x4 crewcab chassis and drivetrain, the PO wanted the cab for his 2wd cc restoration project. I got a cab and clip from a 78 standard cab to put on it. For now I plan on building some sort of flat bed. the second pick is backwards truck!
http://i1093.photobucket.com/albums/...9/IMG_0950.jpg
http://i1093.photobucket.com/albums/...9/IMG_0959.jpg
Old 09-02-2011, 07:57 PM
Feets's Avatar
Feets
Feets is offline
After pulling the bodys off both trucks, and hualing it home, I started this project by pulling the 351m/np435/np205 drive train and tore down the engine. The 351 m had 3 spun berrings and two burnt/cracked exhaust valves, i scraped the engine. I was planing a swap anyway, I'm thinking 460.
Old 09-02-2011, 08:08 PM
Feets's Avatar
Feets
Feets is offline
With the drive train out of the way, I started striping and painting the frame. I used a 6" cup brush on a big grinder and primed and painted the front half of the frame.
I drilled out the cab/frame mount bracket rivets and repace them with grade 8 bolts with lock washers and lock tite. also replaced the transmission crossmember hardware.
Old 09-02-2011, 08:17 PM
Feets's Avatar
Feets
Feets is offline
With the frame painted I moved the cab forward to where it should go. I installed new body mounts and hardware.
Old 09-02-2011, 08:34 PM
Feets's Avatar
Feets
Feets is offline
When I started doing the body work I quickly learned why the PO gave me this cab for free. Rust!!!!!!!!! Never fear, let the chopping and welding begin. The neighbors wont like this, thats ok I dont much like their fancy imported luxury cars.
I whent a head and welded in new floors from NPD, I had to fabricate the section that goes under the seat.
Old 09-02-2011, 08:43 PM
Feets's Avatar
Feets
Feets is offline
I seal welded the whole thing after this pic
Than I ate the chicken
The drivers side, oh yha there was beer with the chicken
Old 09-03-2011, 08:17 AM
teds74ford's Avatar
teds74ford
teds74ford is online now
I know that feeling. Thankfully, I now live in a neighborhood where they don't mind me and my junk.
Keep up the good work. There is nothing more satisfying than totally building a truck to exactly the way YOU want. I did this same thing to the truck in the picture by my username, and it was great! Now I am hooked on redoing these old trucks.
Coltin1992
40
12-10-2017 09:46 PM
rsp0085
1983 - 2012 Ranger & B-Series
03-04-2016 01:49 PM
torch4801
15
07-17-2013 02:51 PM
POS-F500
24
10-06-2011 08:08 PM
masterbeavis
30
11-17-2008 04:58 PM
Quick Reply: '77 F250 4x4 build
