Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 08-02-2011, 01:06 PM
dakonthemountain dakonthemountain is offline
Garage is empty, add now
dakonthemountain is starting off with a positive reputation.
Heater core replacement DONE! -photos
First I want to thank you all for your encouragement and advice during this pain in the A!* project. I hope to NEVER have to do it again. I hesitated even attempting it but through the years on this and the "other" site I have gained knowledge and a bit of bravery to prompt me to try it.
that all said, the difficulty for the heater core itself is minimal, it's the dealer AC in the way that took so long, but thanks to a simple tip I found the Chinese puzzle answer to remove only one bolt holding the right side of the dash in and "tweak" it just enough without bending it to allow the movement of the AC components (evaporator and ducting) out of the way to pull the heater box bolts/motor housing through the firewall. After that the rest went "almost" without a hitch. It took me a total of 10 hours to do this, but if I had to do it again it would now take MUCH less time as I know "the secret".. The only issue I've had was not tightening the heater hose clamp tight enough on re-install (I was just too excited to finish!) When I started the truck and heated it up to pressurize the lines, the hose leaked "just enough" and it channeled through the firewall on the inside of the truck. I panicked at first, thinking the new heater core was leaking! But when I opened the hood I saw it also leaking down the firewall quite a bit. I tightened it, and viola! finished. Because the insulators that were at the firewall were brittle and fell apart when I removed them I am going to silicone the openings around the core nipples to avoid this potential problem in the future. So, here is a link to some photos. I'm not as good as you guys in writing project thread descriptions, but I did put descriptions below each picture. I also didn't post specific photos here to avoid taking up a lot of bandwidth.. Cheers! and thanks again for all your help! Click the image to open in full size.
Dak
PictureTrail: Online Photo Sharing, Social Network, Image Hosting, Online Photo Albums __________________
__________________
Burt, the 1977 F250 Ranger
  #2 (permalink)
Old 08-02-2011, 02:03 PM
cowboywanabe's Avatar
cowboywanabe cowboywanabe is offline
South Dakota Chapter Ldr
1967 Ford F-250
My Garage
cowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputation
Quote:
Dak
Darn, you said you'd never do it again? I was hoping you'd come give mine a try, lol.
I had mine replaced at a shop in December, then they replaced it again in March since it started leaking somewhere. I'm still getting a slight smell of coolant in the cab, but I can't find a leak anywhere... Trying to get brave enough to rip into myself. Mine's got factory AC.
Anyway, congrats on getting it done!
__________________
Rob
1967 F250
Official #10 Slackmaster/#13 Big BS'er
Winter Enthusiast!
Click Here to Join the South Dakota Chapter
Quote:
Originally Posted by dustybumpers View Post
A hero amongst us... My buddy Rob!!!
  #3 (permalink)
Old 08-02-2011, 02:28 PM
DrainBramage DrainBramage is offline
DrainBramage is starting off with a positive reputation.
Thanks for posting this!
I have the dealer AC on my 73 and my heater core exploded the first time I started her up to take her home, lines have been looped ever since. Looks like I need to budget some additional time for the AC removal and core replacement. At least now I can see what I'm in for before I get into it
__________________
1973 F250 2wd Camper Special - 390FE, 600cfm Autolite 4100, DSII w/MSD 6A, NP435, Dana 60 4.56:1 open - haulin' beast (66.6k mi 7/24/11 )
1966 Mustang - built 302, 480cfm Autolite 4100, B/W T5, Currie 8" 3.55:1 LSD - in pieces
1974 Bronco - 302 2v, C4, D20, D44, 9" - 'consulting mechanic' (Brothers project)
1974 Triumph TR6 - 2.5 I6, Twin ZS175CD carbs, 4spd, Panasport 15x6 - the 'fun' project
  #4 (permalink)
Old 08-02-2011, 02:41 PM
ArmyCook's Avatar
ArmyCook ArmyCook is offline
ArmyCook is starting off with a positive reputation.
Quote:
I hope that happens soon! I would be thankful to see thorough pictures on how to fix that stuff. Mine's got the factory AC tho the PO removed the compressor and bypassed the entire HVAC system.
__________________
'77 F250 Ranger 400ci C6 Dana 60 "The Hulk"
  #5 (permalink)
Old 08-02-2011, 05:44 PM
Once I found the magic bolt to remove it went MUCH smoother. Think of it as a puzzle... albiet a difficult one! Good luck!
Dak
__________________
  #6 (permalink)
Old 08-02-2011, 07:34 PM
73f250highboy's Avatar
73f250highboy 73f250highboy is offline
1973 Fiberfab Jamaican V8
My Garage
73f250highboy is gaining momentum as a positive member of FTE.
I had to do that with factory ac. Its much easier
__________________
~Alex
73 highboy with 460 from 72 lincoln.. check out the vid youtube.com/maaproductions2
Check out the build thread http://www.ford-trucks.com/forums/10...ild-story.html
  #7 (permalink)
Old 08-20-2011, 02:18 PM
amodel55 amodel55 is offline
amodel55 is starting off with a positive reputation.
Good job,
I'd about as soon my water wasn't pooring in the floor board. Thanks/Robert
  #8 (permalink)
Old 09-26-2011, 10:53 PM
WPlayer WPlayer is offline
WPlayer is starting off with a positive reputation.
Dak, did you mainly work through the glove box to do this? Or did you have to remove the giant black box under the dash (with the cables attached to it) to do this job?
  #9 (permalink)
Old 12-26-2011, 12:14 PM
wisdum wisdum is offline
1977 Ford F-150
wisdum is starting off with a positive reputation.
Do you have a little bit more information on the 'Magic Bolt'? I am going to tackle my heater core this week while i'm off of work. I have a 77 with AC and I am looking for any hints I can find to make it easier. Great post, the pics look helpful.
Thanks
  #10 (permalink)
Old 12-26-2011, 12:58 PM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.
Quote:
Thanks
For my truck, the magic bolt was the one on the lower right hand corner holding the bottom of the dash on to the "A" pillar on the passenger side. I couldn't get the heater box out no matter how much I fiddled with it. After I found that bolt and took it out, the heater box literally fell on the floor.
__________________
Alan Fenstermaker
'79 F-150 300-6, 4 spd. 4x4
  #11 (permalink)
Old 01-10-2012, 05:35 PM
I'm so sorry I haven't been here to answer the questions!
WPlayer, I worked both through the glove box (after I removed the liner) and yes, had to remove EVERYTHING under the dash, heater boxes, cables, everything!
Yes, wisdum, as earthquake68 said. It was the bolt on the passenger side holding the metal part of the dash to the body. Once I removed that I was able to "tweak" the dash enough to remove the heater box. Remember though, that was for dealer added AC; I don't know the process for factory AC. Hope you had good luck!
Dak
P.S. My truck is gone now.... Burt now lives in New Zealand.... Long story, but it's done. Happy New Year all! :-)
__________________
Tags
1977, 1979, 2004, 79, aftermarket, box, core, exploded, f150, f250, ford, heater, location, replaced, replacement, series, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
