EBC Yellowstuff pads - 1000mi report
I don't think you'll have the fade problem anymore. Those rotors may help some, but the pads are really where it's at!!
That's prolly a good choice for calipers. Mine are all Autozone or Napa and have been good to me so far. Lifetime warranty wouldn't be worth it if I had to change them often.
It was not the slotted part, so much that steered me to the Raybestos R300's, but rather the anti corosion coating differences. I like the idea of them being meticulously machined, especially after reading a article about the problems of too much runout, and the anti corrosion coating is throughout the vaned area, Completely covered. No more rusty brake vanes (at least for a long while I hope)
Rust holds heat, so I want to avoid it if at all possible.
I get it!! Hey, I have seriously considered coating the vanes on a set of new rotors - but have yet to make the time. It couldn't hurt...
I always paint my calipers, brackets, etc anyway. Just hose them down with brakeclean, MEK, laquer thinner, etc and spray a few light coats of 'engine paint'. I dunno whats so special about 'caliper paint', but the 500* engine stuff works great! Sure does look nicer than rusty old calipers.
I have also used the yellow stuff pads on front and was amazed at what an improvement they were. They stopped WAY faster than any other pads! My first set only lasted about 20k miles, though. I tow a 10+k lb toy hauler and would say have a "spirited" driving style, so Im not surprised. My next pads will be yellow stuff! I may look into some vented rotors when these wear out.
I put Yellow stuff on mine about 6000 mile ago - truck stops like it's 2000 lbs lighter. I've made some pretty quick stops with them I don't think I would have made with Wagners. I also run drilled and slotted rotors.
If the CO-PILOT gets too critical on your driving techniques you can just stand on the pedal hard & face plant 'em into the windshield. It'll get quiet real fast! lol
Nothing like dragging up an ancient thread but I wanna know. Sorry for the lost of your Excursion. How many miles did you get out of the pads? I just installed Raybestos professional grade pads and rotors on the fronts. Let's just say that I don't like them very much. They don't bite hard enough. I have been using their police pads and rotors for my Town Cars and have been VERY happy with those. I have less than 1000 miles on the pads and I think I am going to pull them and replace with Yellowstuff.
#28
I've had EBC Greenstuff pads up front for at least 40k miles and the rear pads were 'premium' over the counter stuff from NAPA. The Greenstuff pads were a MAJOR improvement over the NAPA pads I replaced back then. I did not turn rotors for that pad change and they were not warped after running the Greenstuff - even after a caliper locked up and nearly caused a fire!! I've actually been running those pads for the last 15k+ after replacing the caliper(s) - no problems, but now that I'm towing 13k lb Toy Hauler I wanted maximum braking power.
So, when I found out Riffraff was carrying EBC - I called Clay and got a set of Yellowstuff on the way!! Its taken me a few weeks to find the time to install them, but metal-to-metal on a rear brake forced me to do this brake job at RRE. (it was kinda like a Nascar pit stop btw... - THANK YOU Bulla, Mike, Petey and anyone else who was helping!!!!)
I replaced the sticky rear caliper (not slide-pins...) and that gave me (4) newish calipers from Autozone - I did the front (2), then went to replace the rears in NJ, but the AZ part# was wrong for drivers-side and they didn't have what I needed - so we put it together and it 'worked'...
We took (3) rotors (and receipt) back to O'Riellys and took advantage of 'lifetime warranty' - just so I'd have fresh rotors for the new pads. The other rear was replaced last year and looked good. This may not be the intent of the warranty, but my home store doesn't care and I plan to repent at the Pearly Gates.
Driving was IMMEDIATELY different. It takes waaaay less pedal pressure to stop. Not at all 'grabby', just responds to pedal pressure better - the harder you press the brakes, the faster you stop. I've had a couple instances towing where I stood on the brakes HARD and the truck simply did not stop like I wanted it too. I think I'll be able to lock the tires up now if I want (at least make the ABS work!!). The 1000mi was driving thru Smokey Mountains back home and then out to Tulsa, OK - not towing. I have just driven 'normal' after the first dozen or so miles, no hard stops yet (too much JUNK on board to 'test' them properly...)
Just like it says in the literature, they made a little noise after the first 150mi or so - but its all quiet now. I have these pads on my F350 and they do make more dust than the Greenstuff, however I'm ok with that as long as I can STOP whenever I want to. Honestly, I would call the dust comparable to OE and it cleans up easily with clean water and a soft sponge. I really don't know why anyone would sacrifice braking performance to save a couple minutes of detailing time - but thats just me. I'm a 'function before fashion' kind of guy!! I can also say that I have experimented with stopping F350 2-3 times in a row while coming down a grade towing 5ver and there was no noticeable brake fade - don't try that with 'regular' pads!! Also, no need for 'fancy' (aka expensive) rotors if ya use a good set of pads like this. If your rotors aren't warped, just throw these on and roll - if ya need new rotors (don't bother 'turning' PSD rotors, they tend to warp again in short order!), just buy over-the-counter rotors. Those cross-drilled, slotted, cryoed and otherwise molested rotors won't make your truck STOP any faster anyway. A good set of pads will go the furthest in your quest to stop warping rotors!!
Anyway, if I find a product that performs as advertised - I'm happy to share that with others. These fit the bill for me and I feel confident anyone looking for more stopping power AND/or tired of warping rotors will be satisfied with these pads. And thanks Clay for taking such good care of me (as usual)!!!
#29
I put about 30k miles on the X with those pads. That included several cross-country trips at 22k lbs GCVW with the Toy Hauler. I actually took the pads off the wrecked X and put them on my dually, where they have racked up another 20k miles. Didn't realize it was that many miles that until just now! I better check on those things, they gotta be getting close!
