EBC Yellowstuff pads - 1000mi report - Page 3 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #31
Old 08-04-2014, 02:12 AM
MURDOMINO MURDOMINO is offline
MURDOMINO is gaining momentum as a positive member of FTE.
Well i had the EBC "green's" on a ls1 powered T/A a few years back, but didnt really do much driving on the stocks before. Never had any fade, even while at an autocross event. Gonna spend the money through riffraf and get me some Greenstuff now since its taking me a mile to stop this damn truck from 25 mph's up hill!
  #32
Old 08-04-2014, 04:30 AM
GermanMike GermanMike is offline
GermanMike has much to be proud ofGermanMike has much to be proud ofGermanMike has much to be proud ofGermanMike has much to be proud ofGermanMike has much to be proud ofGermanMike has much to be proud ofGermanMike has much to be proud ofGermanMike has much to be proud of
I rebuild my breaks last November and drove about 4kmls since than.
I purchased 4 EBC Dimpled and Slotted Discs and combined them with the
yellow stuff Pads all around....and to top it off I bought a complete set of
Stainless Steel Braided Teflon Lines for the Front and Back.
After a complete brakefluid flush and upgrade to DOT4 fluid I thought really
that I bite the steeringwheel at the first step on the pedal.
Maaaan.....what a difference!
So.....after those mls I can recommened this combination. The dust is average, the pads hold up great and even the dimpled rotors shows only a minimal wear.
.....and I drive sometimes a bit agressive and fast here in Germany.
......all I say is the word AUTOBAHN.
Friends of me drive the mighty Explorer and drive there a similar setup, inspite of the yellow stuff. They swear to the red stuff, because they say, that the red stuff bites as hard as the yellow stuff but even if the breaks are cool. The yellows bite even more if they are hot, where the red stuff bite la bit less in comparison to the yellow pads, because they love high temperatures.
What do you need is the question? Do you like driving agressive and fast or you do a lot of towing in a mountain scenery...than you should get those yellow pads.
Otherwise you would be probably better with buying the red stuff.
Anyway....those EBCs are a very good choice. Pads and Rotors.
Just my 2cents......
BtW.....if youre asking Brent......you dont need breaks at all....stretching your legs like Fred in the Flintstone Mobil is way enough
  #33
Old 08-04-2014, 09:53 PM
LivingLarge's Avatar
LivingLarge LivingLarge is offline
LivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputation
Quote:
I think I'm the only one here that has not been impressed with these. I had green pads in for awhile but they were a bit to noisy for my taste ( I don't want to hear anything!) I went back to Ford brown box pads, think the biggest difference I found were going with new brake lines as far as stopping power. But again I'm definitely the minority here. Just my humble .02
  #34
Old 08-04-2014, 10:03 PM
Magnus E's Avatar
Magnus E Magnus E is offline
Magnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud of
Quote:
I chose to go with Motorcraft pads, the heavy duty version and stainless steel/ Kevlar braided lines. Great stopping power, quiet and good pedal feel. Have to add that I have no experience with EBC and could not give an opinion about those.
  #35
Old 08-07-2014, 07:45 PM
bbacon bbacon is offline
bbacon is starting off with a positive reputation.
Have had the EBC Slotted and Dimpled Hubs on my two wheel drive for two years having turned them once. I use my EX for work and occasionally pull a 12 ft trailer for catering. Have used Yellowstuff for both exchanges and have replaced the calipers once replacing the slide pin kit both times. I have close to 60K miles on the rotors. It was very pricey and I shopped like mad to get the price on hubs and pads rock bottom. I was changing autozone duralast golds every 3 to 5 months like clock work with the warp wobble every time. I felt foolish turning the EBC's but just didn't have the cash for new front hubs. I have almost run the life out of a second set of pads and the turned hubs have yet to give the warp wobble. I did follow the break in instructions and picked up the EBC DVD and did all their recommended install checks. For my money and Time I will go with EBC's again having amazing return on performance. I have looked at other options but there really are not good ones for the two wheel drive EX. The only con is they make dust. You do have to clean the wheels regularly, however, that is better than seeing the autozone guy once a quarter.
As far as the stopping power and peddle ford should have spec'd something similar to this set up at purchase. Its everything you hoped to have. Smooth, rapid, controlled stopping with full cargo and trailer/boat. Plus longevity.
Someone would really have to have a fantastic setup that cost about the same as an autozone set of brakes to make me change from the EBC Sport hubs with Yellowstuff. For what its worth the EBC rep did not feel the Greenstuff would perform with towing and was not recommended by the EBC engineers for a truck as heavy as the EX.
For what its worth.
  #36
Old 08-25-2014, 09:20 AM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
They make noise until they are 'broken in'. Mine haven't made a sound since then.
I'll be towing a 4wd F250 CCSB on a 2-car GN trailer from GA to NJ this weekend and the mountains will put these 'old' pads to the test again.
  #37
Old 08-25-2014, 10:34 AM
jasonodsky's Avatar
jasonodsky jasonodsky is offline
jasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to behold
I absolutely love the stopping power of my yellow stuff. After they were all broken in, I've decided I'll never go to any other pad for my excursion.
  #38
Old 08-25-2014, 11:46 AM
David7.3's Avatar
David7.3 David7.3 is offline
Where is the beer?
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
Where ya going in Jersey?
  #39
Old 09-23-2015, 08:10 AM
pennsylvaniabo pennsylvaniabo is offline
pennsylvaniabo is starting off with a positive reputation.
So i have the cheapest store line of front pads now.....stopping isnt horrid, but the dust is insane. I want to throw a new set of pads on. I tow once a month or so, but it's a 10k trailer when i do. Should I go with a store brand ceramic, or EBC greens?
  #40
Old 09-23-2015, 09:46 AM
RobRoss's Avatar
RobRoss RobRoss is offline
RobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud of
Quote:
This is an old thread and your question is tough to answer since I doubt anyone has any experience with the store pad you mention.
I recently put EBC Green Stuff on the front of my truck and they are awesome! I had HAWK LTS pads but they squeaked and I didn't care for the cold stopping out of the driveway feel. I don't tow that heavy and don't brake aggressively. I plan to tow a car trailer next month about 1000 miles so I'll be curious to see how they perform, I suspect well. They are more dusty than other pads I've tried but they stop the best, by far.
  #41
Old 09-23-2015, 10:02 AM
Immortal_Ben's Avatar
Immortal_Ben Immortal_Ben is offline
Mechanic by Necessity
Immortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud of
I say go for a better pad. Hawk or EBC.
  #42
Old 09-23-2015, 12:01 PM
are the BEC gonna be worse for dust than like a weaver line pad?
  #43
Old 09-23-2015, 03:48 PM
holeshotwalt's Avatar
holeshotwalt holeshotwalt is offline
Spooled Up, Throttle Down
holeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to behold
If they stop better, I say who cares about dust!
  #44
Old 09-23-2015, 05:59 PM
Quote:
That is exactly how I feel about it. If you want low dust and poor braking - get the store-brand 'ceramic' pads. Expect to change rotors more than pads... I do not purchase brake pads based on how much dust they generate! The wearever line SUCKS. All of them.
The EBC Greenstuff are probably slightly less dust than OEM pads. The Yellowstuff are comparable to OEM. The dust is easily washed off with a sponge and clean water if you do it regularly. The amount of dust depends on the type of braking you do. Hard/aggressive braking will produce more dust. I ran these pads with polished aluminum wheels and never complained about dust.
If you do moderate towing and don't brake aggressively, expect long life out of even the Yellowstuff pads. I have used both Yellow and Green - and I see no reason not to just run the Yellow pads. STOPPING is very, very important to me!!! I like the confidence I get running with good brakes!
  #45
Old 09-23-2015, 06:23 PM
fordboy67's Avatar
fordboy67 fordboy67 is offline
fordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant future
I am with Michael (LivinLarge) from earlier, I was very unimpressed with the EBCs I had, I had the green stuffs on for about 5k miles and hated them. I felt no noticeable stopping improvement and the dust was HORRIBLE. Biggest braking difference I have noticed is with new brake lines. I could live with the insane amount of dust if there were a real seat of the pants improvement....it just wasn't there for me, so I guess I'm with Michael in the minority!
Time for brakes again. crazytwo Excursion - King of SUVs 15 03-27-2016 10:21 AM
2001 Excursion Brake Upgrade/Rotor Advise- future towing Trannyman95 Excursion - King of SUVs 18 03-19-2015 12:05 PM
Time for new brakes: anything wrong with power stop rotors and hawk hp pads? hasteranger Excursion - King of SUVs 40 06-16-2013 10:50 PM
Warped front rotor... JetFuelBurner 2007 - 2014 Expedition & Navigator 3 03-13-2013 03:00 PM
Brake upgrade: 14.5: Harley Edition over 13.7" stock SD VonOverkill 1999 to 2016 Super Duty 27 03-02-2011 08:15 AM
Tags
2005, brake, duty, ebc, f250, ford, green, hawk, onford, pads, pickups, power, problems, slot, stuff, super, vs, yellow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
