1991 Ford F150 shifting problems - Ford Truck Enthusiasts Forums
Old 08-02-2011, 12:35 AM
Ecarlton1991 Ecarlton1991 is offline
Ecarlton1991 is starting off with a positive reputation.
Hey my truck has a 351w and it shifts extremely hard while going only about 10-15 mph otherwise it shifts completely fine. it also seems like its shifting late, i know thats not very much detail at all but anyone having the same problem or can help?
Old 08-02-2011, 09:10 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Late hard shifts usually indicate the transmission may be in "limp mode". Try checking for codes before throwing money at the problem. If your truck has an E4OD transmission it is 100% electronic controlled. If you have an AOD you may need to adjust the TV cable.
Old 08-02-2011, 10:35 AM
how do i determine what transmission i have?
Old 08-02-2011, 12:31 PM
rla2005's Avatar
Look at the Door Jamb sticker if it is still on the truck. Use this for reference: Ford Door Sticker Decoder .: Articles
If you have a transmission code "E" you have an E4OD. If it is Trans. Code "T" you have an AOD. Yes I realize the decoder says Trans. Code "T" is listed as 4 speed automatic for a Ranger, but my Ford Service Manual states that T is an AOD in F-series trucks.
If the door jamb stick is gone you can refer to this: Ford Transmission Spotter's Guide .: Articles
I also see you previously stated your truck had a 351W, that by default should make your transmission an E4OD.
Old 08-02-2011, 08:15 PM
okay i have confirmed that my transmission is an E4OD. would rough idling and the shifting problem be from the same thing or do you think they would be completely different problems?
Old 08-02-2011, 10:41 PM
rla2005's Avatar
Most likely different issues. Check for codes before replacing any parts.
Old 08-03-2011, 12:49 AM
do places like Auto Zone check your codes or where do i go to get that done?
Old 08-03-2011, 03:14 AM
rla2005's Avatar
Quote:
Warm up the engine and transmission then do this: Ford Fuel Injection » How To Run a Self-Test
or purchase one of these: Amazon.com: Equus 3145 Ford Digital Code Reader: Automotive
Old 08-04-2011, 08:15 PM
sweet thanks a lot is that link you sent me to Amazon.com an exact digital code reader model that will work for my truck?
Old 08-05-2011, 09:09 AM
rla2005's Avatar
Yes indeed. Many on this forum have one, including me.
Old 08-05-2011, 08:16 PM
awesome thanks for the help i will be ordering one soon!! know anything about B&M shift improver kits?
1991 F150 won't shift into Low Range. Duncansm 1987 - 1996 F150 & Larger F-Series Trucks 14 06-06-2014 07:00 PM
e4od transmission problems JimmyO1331 Clutch, Transmission, Differential, Axle & Transfer Case 3 10-26-2012 01:09 PM
e40d shifting problem Ecarlton1991 1987 - 1996 F150 & Larger F-Series Trucks 16 08-19-2011 05:43 PM
E4OD transmission problem Mi66ss 1987 - 1996 F150 & Larger F-Series Trucks 3 06-25-2011 08:03 AM
1991 F250 7.3 IDI Transmission Problems Pat.Bomb 1987 - 1996 F150 & Larger F-Series Trucks 1 06-20-2011 04:45 AM
Tags
150, 1991, 1992, 49, 91, f150, ford, hard, late, overdrive, problems, rough, shifting, shifts, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
