drive shaft trouble
drive shaft trouble
ok I have a 1974 f100 4x4 and the center collar bearing is out on the rear drive shaft but every where I look it seams that they list the drive shafts with collar bearing as 2x2 should I change it to a diffrent drive line or just look for the same one? the total distance fron t case to rear axels is 75 1/2 " could I get one single axel or would that couse the off roading to be harder?
83capril
13
07-11-2011 07:51 AM
