help! need to remove 4x4 rotor
i dont ever remember having to remove a rotor i did however rebuild all the bearing and everything else in the front hub but any who how do i remove it and please dont say i have to remove the lock hubs and everything else!!!
my brakes blew out and my rotor looks like tracing paper
have new one
have new one
You dont need to remove the lock hubs and everything else......
I lied.. Yes you do.
Basically if you had the bearing out of the front.. you need to get to that point, pull the rotor straight off as itll kind of be held by the grease seal with the other bearing inside the back side of the rotor/hub assembly.
No, you are right. The locking hub, wheel bearings, caliper, and hub assembly all need to come off.
then you do what RLA said, to seperate the rotor from the hub
broncobran68
19
01-24-2009 08:54 PM
jetcityjames
06-22-2005 12:05 AM
Nightrain
05-15-2004 08:29 PM
