Aftermarket Intake Manifold Exhaust Crossover? - Ford Truck Enthusiasts Forums
Old 08-01-2011, 12:10 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is offline
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
Weiand offers a low-rise, dual plane intake manifold called the "Street Warrior," which is a direct competitor to the Edelbrock Performer. This manifold has an "exhaust crossover for improved street drivability." Can someone tell me what that means?
Old 08-01-2011, 01:00 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Many V8 engines have a coolant crossover in the intake manifold, that's where coolant flows to get from one side of the engine to the other.
The M-block engines (351C, 351M, 400, 302C in Australia) had a "dry manifold" in that no coolant crossed in the manifold BUT there was an exhaust crossover.
This was to heat up the carb area for quicker warm-ups in the wintertime.
The crossover was throttled (at least on some applications) so as to keep from overheating the manifold & carb. but I understand many people disconnect that apparatus when they replace their exhaust systems and that can cause problems with gas boiling in the carb bowls.
I have an Edelbrock Performer 400 on my 400 (M-block) in my 1981 F350.
To which engine does this "Street Warrior" thing apply?
Old 08-01-2011, 01:58 PM
LARIAT 85's Avatar
It looks like the "Street Warrior" is a just new name for the "Action Plus" manifold.
This is for a 302 engine:
Weiand 8124 Weiand Street Warrior Intake Manifolds
Old 08-01-2011, 03:50 PM
Old Hickory's Avatar
Old Hickory Old Hickory is online now
Old Hickory is gaining momentum as a positive member of FTE.Old Hickory is gaining momentum as a positive member of FTE.
The exhaust crossover runs under the carb. All intake maniflods from the 60s and 70s
had them for quicker winter warmup. To work it has to have a corresponding opening
on the cylinder heads to route a little exhaust thru intake. Most newer and aftermarket
cylinder heads don't have the crossover provision because most engines now are
fuel injected and don't need the crossover. It was common on high performance engines
in the 60s to block off the passageway for a cooler more dense intake charge.
Old 08-01-2011, 04:07 PM
LARIAT 85's Avatar
That's EXACTLY what I was looking for, Hickory.
Thank you!
Old 08-01-2011, 04:35 PM
Shark Racer Shark Racer is offline
Shark Racer is gaining momentum as a positive member of FTE.
This is also where the EGR will get its exhaust gases on some engines, including my 460.
4.9L Genuine New Ford Exhaust Manifolds and new Crossover Pipe old409 Ford Truck Parts for Sale 1 11-03-2015 11:30 AM
Ford Y Block 292 272 Exhaust Manifolds and Crossover pipe jmadsen Ford Truck Parts for Sale 1 05-11-2015 10:38 AM
parts help for intake components rockittsled 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-14-2013 05:08 PM
391 headers? Spirit of '76 Large Truck 4 08-31-2010 05:37 AM
How Do I Block an exhaust crossover? sabcford 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 10-21-2008 10:34 AM
Tags
302, 40, 400, aftermarket, block, crossover, e7, engine, exhast, exhaust, exhuast, f150, ford, intake, manifold, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
