1995 460 Motorhome FI to Carb
I have a 95 National RV with a ford drivetrain. 460 FI motor and 4sp AODE trans
What I want to do is convert it over to a carb from the FI because I also want to use the propane fuel hat that sits on top of the carb so I can run on either gasoline or Propane.
If anyone knows what all I will have to change to get everything to work I would be grateful. I know electrical and mechanical systems so doing the work is not an issue I am just not up on Ford products especially the AODE transmission and it's sensors
I do not have to worry about Emissions or inspection.
Also I would love to boost torque via a cam swap, maybe have the motor rebuilt as well. Does the motor come out through the bottom of the frame?
I know I am asking for alot of information but if someone can help me like I said I would be grateful
Thanks
Thanks
on
This vehicle has the computer controlled E4OD and the computer that controls it is the same one that runs the engine, so.. you can't simply eliminate the EFI system without providing something to control the trans or swapping in a non computer controlled trans. The options are a rather expensive stand alone trans controller($1000), keep the stock computer but fit the carb motor with all the necessary sensors(Temp, TPS, MAP, Ignition pickup), or swap in a non computer controlled trans but there is really only 1 option here and the C6 is a 3 speed with no overdrive. Additional to all this is the fact that the 460 EFI heads are unique and will also have to be changed to fit a carb intake.
Brad Messenger
06-13-2018 07:59 PM
mltdwn12
10-22-2014 04:49 PM
