HELP !!!someone stole my truck and broke ignition
Hi Guys :
Someone stole my 97 f250 PS diesel and got it back later with body damage and broken ignition .... they broke it right off ... nothing to grab or turn " as i have often heard you can do afterwards ... ' even" with a screwdriver etc... all i can see is a "hole" where the cylinder used to be and nothing really to grab on to " turn " i can't for the life of me figure out how to remove anything to be able to try and start the truck or @ least remove what's broken and put a new key mechanism in it ....
any ideas how it can be done ...
thanks guys
i need the truck to go to work
thanks guys
thanks for the feedback i'll try that ..... i see what you mean .... is there an " easier way persay like crossing some wires under there for now ( like in the movies LOL) until i get it fixed looks like i might need a new sterring column unless that part is replaceable ...i'll try to get a pic
did they catch the thief? lets go pee on him while hes in his cell. there should be 2 (or more) sets of wires you can cross to get the thing started. one (or more) set puts the truck into "run" mode, which youll have to do first, then the other set energizes the solenoid sending juice to the starter. because so many different things are used in the "run" position, it'd be easiest to figure out which two energize the starter solenoid, separate those, and the rest are "run". certain things are cut off from juice once the key is in the start position, so i wouldnt do this for long. in fact, it might not be the best way to go about it by any means, but it'll get ya to the junkyard.
ouch man, sucks to have your truck stolen, havent had this happen to me (great now i may have jinxed my self) but just swap the entire colum out as you won't know what was damaged and what not by the thiefs...
on the same topic would any one have any suggestions for anti-theft deturents? im thinking of hooking a battery disconnect to my truck and using that (can't start what doesnt get power to it) as a deturent...im kinda nervous that thiefs could and may steal my truck (which is my only car btw)
