Dual exhaust on a v10
Hi jlarsen513 and welcome to FTE.
What year is your V-10? The reason I ask is the 3 valve (3V) engines (2005-2010) have pretty decent flowing stock systems and may not respond to a dual exhaust upgrade well. The 1999-2004 engines (2V) have fairly restrictive exhaust systems. You would probably feel a power increasing with dual exhaust......but, there are cheaper ways to get better flowing exhaust in a 2V engine.
well hard to explain without actually having a video but most people think it sounds like a diesel or at least iv had alot people ask if its a diesel. Maybe il try to post a vid in a while.
My 2000 F350 V10 has dual exhaust from the muffler back, but I always thought it came that way factory because I noticed it appeared the pipes were never cut after I bought it from the original owner. I love the sound.Anyone know if once these pipes rust that going to 4 inch would give much better sound and/or power than the stock 3 inch?
Another option for dual exhaust is what is known as "true duals". True duals are one exhaust pipe off of each engine bank running from the header/manifold back to the tailpipe. On the SD and most modern trucksboth pipes have to be routed down one side of the frame rails because the fuel tank is in the way. Routing both pipes down one side creates and unequal length true dual setup which is not optimal.
As for the 4" pipe it will change the tone some but IMO its not optimal for power production, especially down low.
The truck is a '99. I've owned another '99 and I went the route of aftermarket muffler. It changed the sound a little and maybe better throttle response. Just looking at doing something different. I put a true dual with an x pipe on my F150, it made a huge difference I think.
I guess my next question would be dual 3" or 2 1/2". I'd think 3" wouldn't have enough back pressure. Thanks for the suggestions!
Sound like you have a SIDO muffler on your truck. (SIDO = Single In Dual Out) All they did was cut the stock exhaust off right in front of the old muffler and installed the SIDO muffler and dual tailpipes. If you want the dual exhaust look I would recommend going that route. No super duty ever rolled off the line with SIDO setup or dual tailpipes.
Thanks for the info,that explains why I've had a hard time finding the replacement muffler based on this Trucks specs. I finally wound up just taking measurements on the inlet and outlets with the existing muffler size to order a new one.You said that "No super duty ever rolled off the line with SIDO setup or dual tailpipes" so the previous owner must of had a shop weld it together because there is no break between the Cat and the SIDO muffler or between the muffler and the duals coming out.
Some shops fully weld, some use all clamps and some use both. The only place I use clamps on my systems is the muffler.(Along with a couple tack welds) Sometimes a baffle comes loose inside the muffler and you have to replace it. With some work you can usually get the muffler off without cutting the piping: cut tacks, put on the new muffler and reclamp it. I like to avoid short sections of filler pipe if at all possible.
I put a large capacity single in/single out flowmaster on my V-10. I had the exhaust shop curl the pipe around the spare tire, tuck it up out of sight (really liked the no pipe look), and angle cut the end so it was facing the ground for more sound. It sounded like a healthy 5.0. I was talked out of duals, as the shop said they had yet to find a setup any of their customers liked. However, this was many years ago.
