Distributor Installation
I'm in the process of a engine rebuild on my 460, and I am to the point of installing the distributor. I got everything marked, but the problem is, I can't get the oil pump shaft to line up with the distributor. I have tried turning it, wiggling it around, but no luck. The biggest problem is the shaft falls to one side of the hole or another, and I can't get it to move into the center for the distributor to slide in. Any tips on how to get around this?
You didn't say if the engine was on a stand or in the truck, but I had the same problem. I just rotated the engine stand a little and tried to get the rod in the middle of the hole with a long screwdriver. It does take a little fiddling, but you will get it. If it is in the truck, just put a little oil on the end of the distributor to make it as slick as you can. It will be more apt to slide on with a little lubing.
MShepherd2
01-21-2018 06:36 AM
Matthew_Jones
13
05-10-2017 12:29 AM
Culprit83
07-24-2016 10:01 PM
grizz3000
08-07-2007 10:22 PM
1997, 302, 460, 77, back, distibuter, distributor, e250, f250, ford, installation, placement, replacement, replacing, sbf, video
