RTV, How long do you wait? - Ford Truck Enthusiasts Forums
Old 07-31-2011, 03:28 PM
jodaddy jodaddy is offline
jodaddy is starting off with a positive reputation.
I am doing a water pump and was wondering how long everybody waits to fill it up with coolant. I usually wait around 30 min. thanks, Joe
Old 07-31-2011, 03:57 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
There is NO NEED to use RTV on a water pump.
But anyway, by the time you get everything back together, you can fill it with coolant
Old 07-31-2011, 03:58 PM
John Such John Such is offline
John Such is starting off with a positive reputation.
I know this may come off as a smart but reply, But I would read the back of the package or tube..... Believe it or not but the producers of rtv do test their products and their recomendations would help ensure no leaks! And we both know how important that is! Lol
Old 07-31-2011, 04:39 PM
the pump is actually going on my jeep but fte answers way faster. Package only says fully cured in 24 hours but I think it all depends on the size of the contact area. thanks, Joe
Old 07-31-2011, 04:45 PM
Well I'd go by when the stuff in the tip of the tube is pretty set. Not hard but I'm sure you could judge it pretty well. And I agree with diesel brad. It should be good after you get everything back together.
Old 07-31-2011, 06:26 PM
so 3 hours at 80 degrees F was fine after all was said and done. No leaks.
Old 07-31-2011, 07:08 PM
'89F2urd's Avatar
'89F2urd '89F2urd is offline
'89F2urd has a good reputation on FTE.'89F2urd has a good reputation on FTE.
Quote:
so you dont use any sealer whatsoever when swappin a water pump. . . . . . . .
Old 07-31-2011, 07:11 PM
Quote:
I ONLY thing I use on gaskets for the past 20 years http://www.permatex.com/products/Aut...ve_Sealant.htm
If that dont seal it, there is something else wrong. The gasket is the sealer, the Hi-tack is just to hold it in place
The ONLY place RTV belongs on an engine is where the pan gasket meets the front/rear main and where the intake sits in the front and rear of the block. It belongs NO WHERE ELSE on an engine
Old 07-31-2011, 08:02 PM
'89F2urd's Avatar
not using a sealer on the water pump bolts is whats "wrong". whether its thread sealer, rtv, or something akin to either. . .its stupid not to use it. so, to say it has no use on a water pump swap is misleading, because it is perfectly acceptable as a thread sealer since its readily available in just 'bout every DIY'ers garage drawers. as far as the rest of your above said statement, that all depends on the motor thats bein built, and the condition its in.
Old 07-31-2011, 09:21 PM
It has been proven that the proper RTV sealant when used properly and in the right conditions can be just as good if not better than using a gasket. Not including applications were using a metal gasket is vital (head, exhaust, ect...)
Old 07-31-2011, 09:51 PM
It is called thread sealant http://www.permatex.com/products/Aut...ad_Sealant.htm
They way I look at it is. IF the FACTORY didn't use it, neither will I.
i dont know how many water pums you have changed, but i have changed more than the number of cars people will own in a LIFETIME. and i have yet had one come back
Old 07-31-2011, 10:37 PM
Xclimation's Avatar
Xclimation Xclimation is offline
Xclimation is starting off with a positive reputation.
With all due respect:
I know you don't technically have to use RTV. But I still do. Over time parts and surfaces change. They expand and contract get jostled up and down, etc. So naturally surfaces to be sealed may not necessarily be factory smooth. Bolts and threads change as well. If you change bolts, then you are changing other dynamics.
I don't know these things for a fact, but just applying some carefully thought out speculation. I would not change a thermostat without sealant! Sealant also expands and contracts helping seal water better in my opinion.
I too have done numerous car repairs over 30 + years, and can't recall a failure from using gasket sealant. I did not use sealant on my oil pan gasket as it is rubber.
I also like sealant to hold gaskets in place when mounting and assembling and tightening.
Old 08-01-2011, 12:23 AM
CJM8515 CJM8515 is offline
CJM8515 is starting off with a positive reputation.
Well I use RTV all the time, never failed me so long as you dont glop it on heavily. Someone dont want to use it-thier loss.
Old 08-01-2011, 08:27 AM
'89F2urd's Avatar
go back and read what i said. i dont need links to thread sealer. . . . .
rtv is readily available in the diy's garage drawers, and is perfectly fine to use as a thread sealer. . . .
changing more pumps than the amount of cars someone will own in a lifetime, isnt saying very much.
Old 08-01-2011, 08:45 AM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
I agree that you don't have to use rtv. But sometimes its nice to have. I always buy the proper gaskets but I also always keep some rtv in the toolbox just in case. Never know when something might blow out in the middle of nowhere.
How long should I wait before getting an alignment? Shawn MacAnanny Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 29 02-12-2016 11:46 AM
How Long To Wait To Wax A New F250 chickfisher69 1999 to 2016 Super Duty 9 01-29-2016 08:33 AM
VIN has been issued willtim1234 1999 to 2016 Super Duty 2 12-03-2012 09:24 AM
how long to wait before adding coolant? little dutch 1987 - 1996 F150 & Larger F-Series Trucks 5 12-10-2009 01:25 PM
Tags
applying, dry, engine, ford, gasket, grey, leave, long, pump, rtv, sealant, set, start, thermostat, wait, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
