LED Flasher Module
LED Flasher Module
Need to know location of turn signal flasher module on 2008 Ford F250 SD. Am replacing with LED module. The computer does not change the flasher rate until 2011 apparently. Am I correct that the module lies somewhere behind the radio/nav unit and can be accessed by removing the center dash panel. If so, what is the best way to remove the panel?
Thanks,
Thanks,
Your turn signals are controlled by the SJB.
The smart junction box (SJB) is also known as the generic electronic module (GEM).
See your owner's manual for the fuse locations for same; passenger kick panel. Best I can tell this is the SJB or GEM location.
This module detects current to lamps, and too low of current from LED lamp will be considered an open circuit (broken filament in bulb) and rapidly flash.
https://www.fleet.ford.com/truckbbas...s/hotinfo.html
above, all the topics
below, one regarding LED lamps
https://www.fleet.ford.com/truckbbas...tml/Q158r1.pdf
I think you will have to find a dealer that can make the programming changes or you will have to add resistors to create loading on the original circuit.
Good luck, hope this helps,
Bob
Bob
Just do the resistors
I just put the LED tail lights in and added the resistors. Easy job -- there is room to add the resistors right there inside of the housing.
Good luck.
Bigdon68
2008 F350 CC 2WD LB 6.4 Lariat Diesel Auto, Retrax, AirSafe Hitch, CB, Wolo Train Horn, Ride Rites, Aux Tank
2007 Ameri-Camp Summit Ridge Reserve,40ft, Onan, Mor-Ryde IS, Disc Brakes, 17.5 Alcoa Wheels, Michelin Tires, dual AC, king bed
http://community.webshots.com/user/D...host=community
Good luck.
Bigdon68
train460
10-22-2004 10:01 PM
