Operation: Zebra build - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 09-24-2011, 02:48 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Well today wasn't so good.I got new calipers for both sides. But the caliper for teh drivers side is broke from the factory, bleeder screw cross-threaded. But the big issue is the passenger side. The PO used some sort of hardware bolt to hold the caliper on and the knuckle is now completely stripped out.
The graveyard only lists knuckles for the 80-85 style with bolt on calipers.
Ton D44 Steering Knuckle, Left
Can I use these and then just get calipers for an 85? will they bolt up with all my other 95 parts, i.e. the hub and all the bearings?
  #47
Old 09-24-2011, 03:00 PM
Edgethis's Avatar
Nevermind, I was able to get a knuckle from an F150 off ebay for $50. Man I really am begining to dislike the PO.
  #48
Old 09-25-2011, 02:03 PM
Edgethis's Avatar
Some more progress today. I got the new caliper for the Drivers side and it seems to be working well.
Now I noticed a rubbing sound when spinning the wheel. The ABS sensor is hitting the tone ring on the hub I don't know what to do with that one. I'm tempted to just take the Sensor out. The hub and everything seems to be seated properly.
Anyone else run into this issue?
  #49
Old 09-29-2011, 06:07 PM
Edgethis's Avatar
The UPS man brought me a present!
2011-09-29_18-03-22_882.jpg by Edgethis, on Flickr
I was surprised to see teh ball joints are actually in good shape, plus I got the dust shield and spindle bolts. Not bad for $50
  #50
Old 09-29-2011, 06:19 PM
78Explorer 78Explorer is offline
78Explorer has a very good reputation on FTE.78Explorer has a very good reputation on FTE.78Explorer has a very good reputation on FTE.
I'd say you done REAL good!
  #51
Old 09-30-2011, 12:28 AM
Edgethis's Avatar
Thanks. Unfortunately I have to get a tool to pull the old spindle off. I spent about 4 hours trying before giving up for the night.
Question. Dies anyone know if I have to pull the axle shaft to change out the passenger knuckle?
  #52
Old 09-30-2011, 06:44 AM
Yes...you will need to, unless you can figure out a way to install/torque the ball joint nuts with the axle shaft in the way.
Not saying it's impossible, but pulling the axle shaft seemed like the only way when I did the ball joints on both sides of mine.
There may be an easier way that I'm just not aware of.
  #53
Old 09-30-2011, 11:27 AM
Edgethis's Avatar
Ok thanks! I guess I need to clean the arm out first. Don't wanna get all the rust and junk in the slip yoke.
  #54
Old 10-06-2011, 11:46 PM
Edgethis's Avatar
TTB kunckle taken apart
Made some progress tonight.
I got the passenger side knuckle torn all the way down. I am sanding everything down and painting everything over with ultra flat black CARC paint. i like the way it looks on the underbody. I hope to post lots of pictures and updates as I have a 4 day weekend now!
Here's a shot after I finally beat the spindle off. I had to jack the truck up higher so I had room to swing from the bottom to pop the rust seal.
2011-10-06_20-14-26_437.jpg by Edgethis, on Flickr
Here is where I stand currently. Figured after smashing my hand with a dead blow I needed a break.
2011-10-06_23-17-46_604.jpg by Edgethis, on Flickr
  #55
Old 10-07-2011, 07:01 AM
Looking good! sorry to hear about smashing your hand...you deserve a break!
  #56
Old 10-07-2011, 10:38 PM
Edgethis's Avatar
Got some good work done today. I Focused on cleaning and painting the disassembled parts. I decided now was a good time top replace the sway bar bushings as they were stock and worn out. After liberal use of a torch, i got them out. I used a stripper to take all the rust/crud/grime off the parts and then coated everything with 2 coats of CARC ultra black. Heres a shot showing the sway bar links, one stripped and one painted:
2011-10-07_21-17-33_624.jpg by Edgethis, on Flickr
I also put my Deep Creep there, I love that stuff!
Here is what the TTB and radius arm look like now:
2011-10-07_21-53-21_628.jpg by Edgethis, on Flickr
I also went ahead and swapped on the new caliper. I have new Moog sway bar bushing coming in tomorrow. Finally here's a pic of the TTB from the front. I'm trying to clean it all up and paint it so it looks nicer.
2011-10-07_19-28-05_389.jpg by Edgethis, on Flickr
Tomorrow I begin to put it all back together. I think I got a nice amount of work done today.
  #57
Old 10-08-2011, 12:08 AM
ford1977owner's Avatar
ford1977owner ford1977owner is offline
ford1977owner is gaining momentum as a positive member of FTE.ford1977owner is gaining momentum as a positive member of FTE.
very good work, and amazing deals you got, and i also like that tranny pan....keep giving me good ideas lol
  #58
Old 10-08-2011, 07:44 PM
Edgethis's Avatar
Picked up my new Moog Sway bar bushings today. I also went and got some Grade 8 bolts from Lowes.
2011-10-08_11-00-53_493.jpg by Edgethis, on Flickr
Not sure what the 4 round ones on the right are for.
Here's a good shot showing the new bushings in action and also a pic of my spindle and replacement knuckle from an Ebay junkyard truck.
2011-10-08_12-00-52_27.jpg by Edgethis, on Flickr
Nice shiny hub and rotor. I like the way that paint looks and it holds up extremely well.
2011-10-08_14-39-56_701.jpg by Edgethis, on Flickr
2011-10-08_15-27-08_542.jpg by Edgethis, on Flickr
I also replaced the Passenger side Tie rod and the connecting sleeve as well. i plan to replace the rest of the steering linkage in the next few months.
Heres a photo all put back together. Now I just need to find someone to help me bleed the front brakes properly
2011-10-08_19-08-43_245.jpg by Edgethis, on Flickr
  #59
Old 10-21-2011, 08:04 PM
Edgethis's Avatar
Alright, haven't worked on the truck much lately, but this weekend I am hoping to complete my floor shifter install. The brakes seem to work ok, but still doesn't stop like I feel it should after new rotors and pads and calipers. Might need to adjust teh back brakes. Anyways, I'm gonna have a bit m,orte of a hassle with my trans pan swap as my Custom Y-pipe sits right under the back part of the pan that dips up. I'm draining the fluid now, hopefully I'll have enough room to slide it foward and down. I really don't wanna have to pull the header and leg of that pipe. (already scoped that avenue as a last resort/ultimate fail of the exhaust shops part)
  #60
Old 10-21-2011, 10:01 PM
Edgethis's Avatar
Minor snag. I have the shifter rod installed (hard part) unfortunately I didn't notice that the new linkage on the outside mounts downward inste3ad of upward like the stock set-up. So now my exhaust is in the way (my Y-pipe for the Longtubes). I am gonna button up the transmission as is for now.
I guess I'll have to go to the exhaust shop on Monday and see what it'll cost to bend that one section downward a few inches. Thankfully I had been planning this process so I didn't have them weld my Y-pipe together, rather its in pieces and then clamped together with exhaust sealant at the seams till I got everything done.
Project Murphy - 93 2wd F150 BigBF150 1987 - 1996 F150 & Larger F-Series Trucks 3 05-12-2015 12:20 AM
$4500 for '75 Bronco? Realm 1966 - 1977 Early Broncos 6 03-27-2015 10:40 PM
need value of restore!!!! liveFORDorDIEhard 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-14-2015 10:46 AM
*Geek Rant* Upgrading from Windows 8 to Windows 7. Furyus1 General NON-Automotive Conversation 20 06-05-2014 06:31 AM
What did you guys do? Cat906 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 04-03-2014 09:03 PM
Tags
bronco, build, camouflage, ford, job, nugents, operation, paint, picture, special, stripe, stripes, ted, truck, trucks, zebra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
