Operation: Zebra build - Page 3 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
  #31
Old 08-17-2011, 07:36 AM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Yeah. Transmission shifts alot lower at WOT. Has more noticeable off the line power. Not to mention the deep roar it let's out when you floor it
  #32
Old 08-23-2011, 08:09 PM
Edgethis's Avatar
New video, gonna add the link as soon as my internet decides to upload from my phone!
Also I'm debating between rebuilding my transmission or swapping in a C6. Any suggestions?
  #33
Old 08-23-2011, 09:16 PM
Edgethis's Avatar
95 zebra bronco 351w headers exhaust - YouTube
Pacesetter full length headers into a custom 2.5" Y pipe
Flowmaster Super 44 2.5 in 2.5 out single exhaust turned down just behind the axle.
Hope you guys like it.
  #34
Old 09-08-2011, 05:54 PM
Edgethis's Avatar
Got a new Trans pan! This one is from Rock Auto and it only cost me $33 shipped to my door. This pan has the drain plug built in.
New trans pan E4OD by Edgethis, on Flickr
PS it came with that magnet, so I figured Id add it for your veiwing pleasure.
  #35
Old 09-08-2011, 11:32 PM
NewEnglander's Avatar
NewEnglander NewEnglander is offline
NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.
Sounds pretty damn good.
  #36
Old 09-08-2011, 11:40 PM
Edgethis's Avatar
Thanks! Its gotten deeper as the muffler breaks in.
Im currently working on a Floor shifter install for the E4OD, pics and tips coming soon, hopefully. I have it all installed, just have to actually hook teh cable to the trans.
  #37
Old 09-20-2011, 11:52 AM
Edgethis's Avatar
So, I replaced my rear window motor this morning as it'd gone out a while back. Figured I better fix it before winter. I did not know that as soon as you remove the motor, the dang regulators slam up like a bear trap! The after trying to get thenew motor in with the regulators in place for about a half hour, I began wondering if maybe I need to hire a contortionist to do this or (light bulb) unbolt the window regulator so i have better access. Everything went super smooth after that. Now I have to replace that dang dash switch so I don't have to get out to roll it up/down.
  #38
Old 09-20-2011, 11:55 AM
Edgethis's Avatar
O and I noticed, the electrical tab where I assume the Defrost wire clips on, but I didnt see a wire anywhere. Does anyone have a diagram or know where I might find it? Thanks
  #39
Old 09-21-2011, 01:37 PM
Edgethis's Avatar
Ok I decided to move foward with my floor shifter project. I started by ordering the Winter's shifter kit from the graveyard. I was a little disappointed once I realized that this was in no means a "bolt on" conversion as the site kinda makes it sound. First off their physically isnt room to mount teh shifter and have full operation on the stock floor pan. Its either hitting the dash or hitting the center console. Secondly, you have to dismantle part of the transmission to install their shifter arm/rod. I'm not sure whay they couldnt make a kit to mount onto the factory arm.
My problem is that my transmission works...mostly it does have hard shifting issue so I didnt wanna tear into and do something that would cause it to not work for the time being. Also, I don't know how to weld. I plan on taking classes but spare time is rare. So making a custom mount wasnt really an option either.
i have the mount together and I took pics of the process but it was made completly bolt on. I just coated it with bedliner so it'll match the rest of the interior for now. Pics to come tonight! (hopefully) as my work computer won't let me go to any of the picture hosting sites. (lame)
  #40
Old 09-21-2011, 03:50 PM
Edgethis's Avatar
This is the kit as I got it from the Graveyard.
2011-09-02_13-04-27_328.jpg by Edgethis, on Flickr
Here is what I decided to use to make the mount for my shifter. it an ammo can for 5.56 rounds if anyone's wondering.
2011-09-21_10-29-02_844.jpg by Edgethis, on Flickr
Here is my mount after measuring and trimming it down to the appropriate size.
2011-09-21_11-39-43_473.jpg by Edgethis, on Flickr
Here is the whole assembly put together so I could make sure it all lined up as planned.
2011-09-21_12-36-10_437.jpg by Edgethis, on Flickr
It was a pain to get the cable connected as I already had the cable fed through the floor.
2011-09-21_14-35-46_84.jpg by Edgethis, on Flickr
And finally here is the end result! I like it but I may add a longer handle/ different shifter to make it feel more comfortable.
2011-09-21_15-10-54_63.jpg by Edgethis, on Flickr
Here soon, I will show how to hook the cable to the transmission.
  #41
Old 09-21-2011, 06:08 PM
78Explorer 78Explorer is offline
78Explorer has a very good reputation on FTE.78Explorer has a very good reputation on FTE.78Explorer has a very good reputation on FTE.
NICE job!!!
I also like the new tranny pan! May have to get one of those!
  #42
Old 09-21-2011, 06:32 PM
Edgethis's Avatar
Thanks!
I figured if I was gonna have to drop the trans pan to pull the valve body may as well upgrade the pan. Heck for $33 its a deal just to get one and keep it on a shelf till time to change trans oil.
  #43
Old 09-21-2011, 06:48 PM
I couldn't agree more...servicing the tranny on mine is next on my list...that pan will be perfect!
  #44
Old 09-23-2011, 11:08 PM
Edgethis's Avatar
Finally found a good deal on rotors and hubs.
2011-09-23_18-58-17_143.jpg by Edgethis, on Flickr
Got all that for right at $200! Good deal I feel.
Here's a before picture of what i had to begin with. I didn't know it but the caliper is seized, thus causing the warping and grooves on the rotor. Also glad I chose to get the hub assembly as the previous owner must have beat the passenger hub with a sledge for fun. I was barely able to get the lockout assembly out.
2011-09-23_19-10-31_67.jpg by Edgethis, on Flickr
Here's an after pic! Nice and shiny!
2011-09-23_22-31-06_337.jpg by Edgethis, on Flickr
2011-09-23_22-30-43_440.jpg by Edgethis, on Flickr
Now I have to wait till tommorow, I'm gonna get new calipers and pads.
  #45
Old 09-23-2011, 11:32 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant future
Good goooood... - rubs hands together -.
$4500 for '75 Bronco? Realm 1966 - 1977 Early Broncos 6 03-27-2015 10:40 PM
*Geek Rant* Upgrading from Windows 8 to Windows 7. Furyus1 General NON-Automotive Conversation 20 06-05-2014 06:31 AM
So my girlfriend wants a Ford Bikini...... Scotter06 General NON-Automotive Conversation 25 04-06-2006 12:12 AM
rear window slider Zebra 1987 - 1996 F150 & Larger F-Series Trucks 1 10-11-2003 11:57 PM
surface rust on a 67 F250 ralph_the_tech Paint & Bodywork 2 08-18-2003 07:38 PM
Tags
bronco, build, camouflage, ford, job, nugents, operation, paint, picture, special, stripe, stripes, ted, truck, trucks, zebra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
