Operation: Zebra build - Page 2 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 08-05-2011, 10:21 AM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Well I blasted the headers and am coating then with a few coats of ceramic aluminum paint. Ill bake then later on.
Sadly, after calling numerous exhaust shops my X-pipe idea is dead. i got everything from it won't fit, we won't try, and even X-pipes are illegal.....I even stated strongly that I wanted to replace the cat(s), somehow they think that all cats need the factory air tube and also I must keep two cats....ugg.
I did manage to convince one shop that it was at least ok to do a Nice 2.5" Y-pipe with a single 3 way cat without AIR injection.
Now, I debating keeping the dual tips out the back ( I already have 2.25 duals straight out the back, I know about the fumes lol), OR Doing a single out the side in either factory location or just in front of the tire. What do you guys (and gals) think?
Old 08-05-2011, 05:38 PM
Edgethis's Avatar
Header update!!
I got the drivers side manifold off. Thankfully I've been soaking the bolts with penetrating oil for the past 2 weeks. Its really helped so far. Im taking lots of pictures as well. Biggest PITA so far is removing factory y-pipe.
Old 08-06-2011, 10:08 AM
Edgethis's Avatar
Here is what I started off with. I had removed all the air pump crap last weekend.
I now realize why I was constantly getting an EGR flow code. The dang tube was broke down past where I could see with everything in the way.
Here is a picture showing the drivers manifold with all the wires out of the way.
The passenger side, it looks cramped but this side is actually easier to get the header on.
Here is a pic with the header and new EGR set-up bolted in place.
I have both headers in place and partially bolted to the block, I'm going to get some washers/lock washers for the bolts so that I dont have to worry about bottoming the bolt out and breaking a head off. More pics to come! Also you do have to drop the drive-shaft at the front diff, but other then that the headers side right up into place.
Old 08-06-2011, 10:29 AM
njneer1's Avatar
njneer1 njneer1 is offline
njneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to all
Good thread .....Headers can be a pain.....make sure you tack weld the collector ring to the header.....and the other ring to the collector......stops the movement.... and makes the collector gasket last.
Old 08-06-2011, 10:53 AM
Edgethis's Avatar
Well these headers came with u-bolts for the collectors. I plan on getting some collector rings and having the shop that fabs my y-pipe put them on.
Old 08-06-2011, 11:54 PM
Edgethis's Avatar
Got both headers on today, here's a quick shot of the drivers side with header
They don't hang down nearly as much as I thought they would.
I did have to relocate the O2 sensor to the driver's side due to no room on pass side where they put the bung:
Hopfully that wont effect too much.
I did fire the truck up and let it run to make sure that I got everything back together correctly. I'm a little concerned about my plug wires as the passenger side has some angled so that they touch the header. I'll have to wrap them and try to get them away somehow.
I have a Magnaflow hi-Flow cat and Flowmaster Super 44, I like the 44's sound, that'll go on here hopefully Tuesday the shop can make my Y-pipe. With the price they're gonna do it for I cant complain.
If you guys want any more pics of anything just ask, hopefully this will help some people decide if they want to do full length headers on their Broncoor not.
Old 08-09-2011, 05:44 PM
Edgethis's Avatar
Ok status update: I got the exhaust finished today. The new Y pipe looks great. The shop snaked it around the transmission pan and has the two sides coming together just past the transmission crossmember. They put a turndown just behind the axle so that it doesn't hang down. The whole exhaust is above the level of the frame so I lose no ground clearance off road!! Only bad thing is that the exhaust bangs against a crossmember but they are gonna fix that tommorow by adding a new hanger. The total cost: to fab the y pipe and install the cat and muffler using clamps so I can take parts off to upgrade/service things...$132 pics to come shortly
Old 08-09-2011, 08:35 PM
94 XLT White/ Silver 302's Avatar
94 XLT White/ Silver 302 94 XLT White/ Silver 302 is offline
94 XLT White/ Silver 302 is gaining momentum as a positive member of FTE.
Sounds like a really good price to me. I like the long tube headers.
Kenny
Old 08-09-2011, 09:25 PM
Edgethis's Avatar
I think it was a great price as one shop quoted me $275 to fab a y pipe!
Old 08-09-2011, 10:51 PM
Edgethis's Avatar
2011-08-09_18-56-55_829 by Edgethis, on Flickr
2011-08-09_18-57-16_422 by Edgethis, on Flickr
I went with clamps for now so I can still take parts off if I wanna change it or work on other parts of truck. It sounds awesome! Video to come soon.
Old 08-13-2011, 07:24 PM
danohall danohall is offline
danohall is starting off with a positive reputation.
Question for you Edgethis....is your catalytic convertor a dual inlet style or can you post a pic of how the shop did the 2 into 1 join before it goes into the converter?
Thanks
Old 08-14-2011, 09:06 PM
Edgethis's Avatar
Ill post a pic up for you in the morning if I can remember lol. They actually made a Y pipe instead of using a premade one. The Y is right at the trans crossmember. its a single in/out magnaflow Hi flow Cat.
  #28
Old 08-16-2011, 07:17 PM
Edgethis's Avatar
Sorry for the delay, heres a few pictures of the Y-pipe.
2011-08-16_16-45-46_464 by Edgethis, on Flickr
2011-08-16_16-46-03_507 by Edgethis, on Flickr
I wanted them to snake it around like that so that crushing it wasn't a problem and also hopefully I can get an extra capacity trans pan on there still. It does look like you could cram an X-pipe and true duals in there tho...
  #29
Old 08-16-2011, 08:03 PM
Those are perfect!! Thanks for posting them
  #30
Old 08-17-2011, 01:00 AM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
Did you notice any performance improvements?.
Project Murphy - 93 2wd F150 BigBF150 1987 - 1996 F150 & Larger F-Series Trucks 3 05-12-2015 12:20 AM
$4500 for '75 Bronco? Realm 1966 - 1977 Early Broncos 6 03-27-2015 10:40 PM
need value of restore!!!! liveFORDorDIEhard 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-14-2015 10:46 AM
*Geek Rant* Upgrading from Windows 8 to Windows 7. Furyus1 General NON-Automotive Conversation 20 06-05-2014 06:31 AM
What did you guys do? Cat906 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 04-03-2014 09:03 PM
Tags
bronco, build, camouflage, ford, job, nugents, operation, paint, picture, special, stripe, stripes, ted, truck, trucks, zebra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
