I want to add a trans temp gauge, maybe a digital voltage, and a small tach if I can find that. I was thinking summit Racing or maybe even JC Whitney.
This new van is so quiet I can't even hear what the engine is doing at highway speeds with the radio on. I'd really like a tach but a trans temp is vital.
Along with whatever gauges you eventually settle upon adding maybe consider Autometer gauge pods too. They have pillar mount as well as overhead versions, p/n 18017 & 18018.
Autometer trans temp and vacuum gauges in an Autometer pod
with Eqqus tach in my '01 E-350.
[IMG][/IMG]
Summit and Jegs are sources I use.
JC Whitney does not have the reputation for me to use.
BTW what vehicle do you have?
[IMG][/IMG]
Shorebird, or anyone, is this a universal Autometer pillar pod or specifically made for the E-series? I want a 3 gauge pillar pod for my 95 van and haven't found it yet. Color change no problem.
JWA, the overhead style you gave numbers for won't work for me unfortunately.
Absolutely NOT........Real Performance Guages are worth 3-4 Times more expensive than Stock.......( Mine are all Auto meter Ghost ( Boost, Pyro ,Trans T* ) ...... did not even paint it...I just cut a access hole the bottom of the stock pillar , and ran my Chit...then attached the pillar Pod with Screws & I was Styling and Profiling......Ok , I had to drill the Manifold and Install the Thermocouple but , It is not that Involved.... I keep it simple........
