Best source for pillar pod and gauges? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-31-2011, 09:20 AM
86scotty's Avatar
86scotty 86scotty is offline
86scotty is starting off with a positive reputation.
I want to add a trans temp gauge, maybe a digital voltage, and a small tach if I can find that. I was thinking summit Racing or maybe even JC Whitney.
This new van is so quiet I can't even hear what the engine is doing at highway speeds with the radio on. I'd really like a tach but a trans temp is vital.
Old 07-31-2011, 02:24 PM
jamnjm jamnjm is offline
jamnjm is starting off with a positive reputation.
You might would like to consider a vacuum gauge as for engine condition and for mileage...
Old 08-01-2011, 07:03 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Along with whatever gauges you eventually settle upon adding maybe consider Autometer gauge pods too. They have pillar mount as well as overhead versions, p/n 18017 & 18018.
Old 08-01-2011, 07:35 AM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Autometer trans temp and vacuum gauges in an Autometer pod
with Eqqus tach in my '01 E-350.
[IMG][/IMG]
Summit and Jegs are sources I use.
JC Whitney does not have the reputation for me to use.
BTW what vehicle do you have?
Old 08-01-2011, 12:11 PM
86scotty's Avatar
Thx, JC Whitney isn't my favorite either.
02 e350 5.4l
Old 08-01-2011, 01:32 PM
JC Whitney doesn't make any products....just buys & resales them.
Old 02-06-2014, 10:32 AM
86scotty's Avatar
[IMG][/IMG]
Shorebird, or anyone, is this a universal Autometer pillar pod or specifically made for the E-series? I want a 3 gauge pillar pod for my 95 van and haven't found it yet. Color change no problem.
JWA, the overhead style you gave numbers for won't work for me unfortunately.
Thanks!
Old 02-06-2014, 10:40 AM
JWA's Avatar
JWA JWA is offline
Scotty you might want to call AutoMeter----their catalogs and website leaves a lot to be desired.
Even though some of their gauge pods will fit E-Series they're not so forthcoming which those are.
Old 02-06-2014, 03:33 PM
blageurt's Avatar
blageurt blageurt is offline
blageurt is gaining momentum as a positive member of FTE.
Old 02-06-2014, 06:12 PM
redtanrt10's Avatar
redtanrt10 redtanrt10 is offline
redtanrt10 is starting off with a positive reputation.
blageurt, thanks for posting
With this set up do you still have accessibility to the "grab handle" on the pillar?? thanks, Mike
Old 02-06-2014, 09:47 PM
blageurt's Avatar
Absolutely NOT........Real Performance Guages are worth 3-4 Times more expensive than Stock.......( Mine are all Auto meter Ghost ( Boost, Pyro ,Trans T* ) ...... did not even paint it...I just cut a access hole the bottom of the stock pillar , and ran my Chit...then attached the pillar Pod with Screws & I was Styling and Profiling......Ok , I had to drill the Manifold and Install the Thermocouple but , It is not that Involved.... I keep it simple........
Tach and Temp gauges not working!!! Matt Manley 6.0L Power Stroke Diesel 4 01-10-2016 08:53 AM
molded floor mats MattEich 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-10-2015 08:17 PM
Installing new carpet.. recommendations? AtlantaBoy 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-19-2015 07:22 PM
Gas Tank Amish Ford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 03-01-2015 09:13 PM
Where to add water temp sender and how to wire tach and voltmeter on 460? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 28 06-29-2014 11:45 PM
Tags
1997, e350, expedition, ford, pillar, pod, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
