1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
my new front level lift(installed)
Old 08-24-2011, 09:12 PM
Quad Racer's Avatar
Quad Racer
Quad Racer is online now
Nice work. I'm thinking of what setup I want. This does appear to be an excellent option!
Old 08-25-2011, 09:39 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
i tow a 8k gvw utility trailer with a 30HP john deer tractor with bucket and 7ft backhoe attachments, a 20ft key west CC on a double axle trailer, and a few loades of fresh cut wood for the wood stove in the winter so i wont freeze in my garage.
Old 08-25-2011, 09:47 PM
SuperDutyScaler
i know the front springs will settle after a few months so it will hopefully have two inches of rake. right now its a little nose high for me. im worried that when i put a full load of wood, dirt something really heavy in the bed the front will be pointing at the sky.
Old 08-25-2011, 09:48 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
perfect height i think! looks great!
Old 08-26-2011, 09:56 PM
sean23johnson's Avatar
sean23johnson
sean23johnson is offline
looks perfect.
I may have missed it but are those stock 265/75/16 sized tires??
Old 08-27-2011, 04:27 AM
mountie's Avatar
mountie
mountie is offline
Truck looks great. I just bought a low mile 07 F350 Diesel and that's the first mod I'm gonna do to it. A nice levelling kit.
Old 08-27-2011, 03:49 PM
SuperDutyScaler
no im running 285 75R16's
Old 08-27-2011, 04:39 PM
Benny76's Avatar
Benny76
Benny76 is offline
So, if you're running 285 75 16's and I'm running 275 70 18's we have close to the same height tire. Maybe mine wouldn't look goofy going up another couple of inches in the front!! I like yours.
Old 08-14-2016, 09:43 AM
SuperDutyScaler
I was looking up pics of lifted ext cabs to see what I'd like for wheel package on my truck. And I came across pics I posted when I did my level springs on Google. I reread my posts and thought let me go double check my measurements and post them up so you guys can see how the pro comp springs are holding up. So here we go, tape measure from ground to bottom of wheel well lip's just like before only difference I've changed tires from BFG all to bridgestone revo2 that are brand new...
LF 42" RF 42 1/4"
LR 44" RR 44 1/4"
Old 08-16-2016, 03:15 PM
87beater's Avatar
87beater
87beater is offline
I'm looking at putting the same springs on my '03 7.3L. You said that the adjustable trac bar was required, correct? I'm looking at replacing the shocks with 2" lift Bilsteins as well.
Old 08-22-2016, 09:43 AM
SuperDutyScaler
Actually no the adjustable trac bar wasn't necessary, I had to cut I think 1/2 to 5/8 of an inch off either side so I could get to it short enough after the install. I checked the axle about a year after I did the springs for "settlement" and I turned it a 1/2 turn shorter to realign the hole properly. I installed the trac bar because I plan to do a 4" lift and I wanted to have the adjustability for my future plans and to have the axle centered correctly if the drop brackets were off
JetExpress_6.7
Ford Truck Parts for Sale
07-03-2015 10:39 AM
FordMuddin'
11-08-2012 12:21 PM
F-250 Super Duty
17
07-11-2009 09:27 PM
ATXZJ
Modular V10 (6.8l)
04-07-2008 08:45 PM
52'F-3
04-18-2007 01:48 AM
Quick Reply: my new front level lift(installed)
