Have you looked at the Swamp 175 tow stage one injectors? They are supposed to be brand new with new parts from my understanding, and are about 15 bucks more for a complete set after core, and look to be cheaper with the + core charge.
Installed a set of NEW AC's (160cc with stock nozzles) on Chelseas Excursion a few months ago, very nice and a solid 350hp injector. With some 100% nozzles they would hit very close to 400hp.
That's the only thing I wish I had done differently with mine. I wish I had a set of 100% nozzles swapped in.
I'll probably have mine pulled and send them off to Cass and have him install a set next year.
If I ever get the cash, I'll have a set of AC's with 100% nozzles installed in my wife's Ex.
Nice to see you posting again, Joe.
Stewart
I was under an EXTREAM time crunch when I did Chelsea's... She would have had 250/200 hybrids if someone would have had them in stock. I called about 6 different vendors and builders and OVERNIGHTED the AC's home!!!
I was not disapointed as soon as it fired up! Best running, sounding driving 7.3 I have ever experanced.
I do NOT worry about Chelsea being stranded due to an injector issue or a blown motor.
I am hoping to do the same at some point, throw a set of 100% nozzles on them.
Yep, same here. No worries at all.
I do wish I was firmly in the 14's when drag racing. I know a properly working rear diff along with bars to eliminate axle wrap and a set of slicks would do that already, but I also know that with a diff, bars, slicks AND 100% nozzles, my truck would be in the low 14's.
