Electric fan selection for 55 F100
I can't seem to be able to link it now, but there is a great article on three fans that are good for our trucks.
It is on "460Ford.com" site. search BBR cooling issues.
I had decided if I was going to use a electric fan, that based on this info, the one i would choose would be the cooling fan for a Chevy HHR. it moves about 4000 cfm. and you can buy it new from chevy parts dealer for $75.00. It is only 4'' deep and fits a 22 inch radiator very well.
I didn't go further because I decided to keep my mechanical fan.
The other two discussed were the Lincoln MKVIII and ford taurus
on
No I do not have any pics as I am really bad at documenting things on film, if anyone remembers what film is ..... the temp sensor I used is from a Fiero, it activates a relay that turns the fan on.... I also installed an override switch so I can manually turn the fan on.... which I do most days now.
on
Ok I borrowed one of those "new-fangled" digital cameras and took some pics of the fan, they are very ugly and make the truck engine bay look very dirty and rusty, so I only put up two of them ...... it is not really that bad looking but I guess I could clean it... but then again it is driving season not cleaning season here
I put them in my album... under my public profile
Does it HAVE to be a wrecker fan?
Here's a pic of a truck in our club, the guy who built the truck had a number of radiator shrouds built to his spec out of stainless steel. The shroud in the pic is one of these and is made to bolt up to a stock radiator (the radiator in this pic is not stock but the dimensions are OEM). I have one of these shrouds and a 16 inch electric fan that fits it. I can take some measurements if you like.
on
I would have used a mechanical fan but my engine sits so low that only half of the rad would be covered by the fan arc... so I went electric
You could use a Taurus fan out of a Volvo. It is the famously powerful two speed Taurus fan motor, but Ford redesigned it to unbolt out of the shroud easy peezy. It also comes with trick automatic low/high relay pack.
The advantage of using an oem fan is that they are built to a much higher standard than the aftermarket fans.
omnithesis
10-17-2004 12:09 AM
