Trans temp sender install on E4OD - Ford Truck Enthusiasts Forums
Old 07-30-2011, 06:33 AM
larspetter123 larspetter123 is offline
larspetter123 is starting off with a positive reputation.
Hi,
Just bought an Autometer Trans temp gauge. It came with the standard 1/8 NPT sender. I will install this sender in the service port on the drivers side of the trans.
The probe on the sender from Autometer is half an inch long measured from the tip of the probe to the threads. Does anyone know if this probe is ok for E4OD, or is it too long and will come in contact with trans internals?
//Lars Petter
Old 07-30-2011, 09:18 AM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
snaponprofile is starting off with a positive reputation.
Put the sender in the side test port and call it a day.
Old 07-30-2011, 10:05 AM
Coalroller's Avatar
Coalroller Coalroller is offline
Coalroller is starting off with a positive reputation.
youll be fine our glowshift temp sender was that length and it went in great and doesnt come in contact with anything
Old 07-30-2011, 11:24 AM
Quote:
Is the oil level below this port with engine off?
//Lars Petter
Old 07-30-2011, 11:33 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is online now
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
it will just dribble a few drops of trans fluid when you remove the plug.
hardly even need a rag for.
trans temps here should be 150 absolute bare minimum once up to temp.175 ideal trans temp.200 still safe,but the trans fluid would need to changed more often.installing an external trans cooler,and possibly playing with its mounting location can help you average the ideal 175 under normal operating conditions.
http://www.digi-panel.com/trannyoil.htm
Old 07-30-2011, 06:26 PM
eatont9999's Avatar
eatont9999 eatont9999 is offline
eatont9999 is starting off with a positive reputation.
How is the temp probe sealed into the port? Teflon tape or is it compression. I need to know be cause a trans temp gauge is on my list of things to do. Is there anyone with a picture of the port?
Old 07-30-2011, 07:37 PM
84-6.9L's Avatar
84-6.9L 84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
Its pipe thread put some tape on it but don't go overboard.
Old 07-30-2011, 08:35 PM
I just tightened mine up pretty good and it never leaked.
Old 07-30-2011, 09:44 PM
Quote:
drivers side of trans.
http://www.ford-trucks.com/forums/10...test-port.html
Old 07-31-2011, 10:53 AM
Coalroller's Avatar
fordf250 beat me to it but i also have a few pics in my gallery of the port also
Old 08-03-2011, 02:11 PM
Just completes the install. But the sender seems to be too long. It will not enter completely into the port. I can feel resistance when trying to thighten the sender, so I have only thightened it very careful so far because I am afraid I might destroy something. And I have not started the engine after the install so far.
The bolt that I removed from the trans test port is appr a quarter of an inch (appr 7mm) long measured from the tip to the beginning of the threads. The sender is half an inch (appr 13mm) measured from the tip to the beginning of the threads.
Any who knows if it is ok to use this sender the way it is installed now, or should I get a shorter one?
If I should use a shorter sender, does anyone know where I can buy one online?
Appreciate your help.
//Lars Petter
Old 08-03-2011, 04:43 PM
eatont9999's Avatar
It sounds like no one on those other threads can make ups his or her mind about where to install the sensor. It is easier for me to install it in the test port but it is also easier to install it the first time correctly than twice.
Old 08-03-2011, 04:49 PM
That sounds weird, mine was about that length and went in no problem.
Old 08-03-2011, 05:22 PM
eatont9999's Avatar
That's what he said... Sorry, I couldn't let that one go.
Old 08-03-2011, 06:14 PM
greywynd greywynd is offline
greywynd is starting off with a positive reputation.
Did you try a screwdriver or wire or anything to see if you feel anything?
Trans temp Sender Crewcabber 1987 - 1996 F150 & Larger F-Series Trucks 3 09-08-2015 07:11 PM
Max Trans temp sender length for E40D if installed at Test Port SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 17 05-25-2014 08:11 PM
Temp. sending unit E40D fuzzy1626 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 07-15-2010 10:46 AM
ZF5 temp gauge question rolltide3006 1994.5 - 1997 7.3L Power Stroke Diesel 5 07-06-2010 01:30 PM
Trans temp gauge not working YellerMax 1999 - 2003 7.3L Power Stroke Diesel 14 12-07-2006 12:12 PM
Tags
2l, alpha, e4od, fabric, ford, gauge, guage, hyvent, install, place, port, sender, sensor, temp, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
