Short to ground at battery after hooking up jumper cables in reverse for 30 min. - Ford Truck Enthusiasts Forums
Old 07-29-2011, 11:41 PM
mike 96 ws6 mike 96 ws6 is offline
mike 96 ws6 is starting off with a positive reputation.
My friend had a no-start (low battery) on his 86 F150 4x4 4.9 so he hooked jumper cables from his Crown Victoria and went inside the house for 30 min.
When he came back to the truck he realized he had hooked up the cables wrong. The Crown Vic battery and truck battery were both dead. And several wires were burned up on the truck. I was able to get his Crown Vic repaired by replacing a fuse and charging the battery.
I didn't have time to try diagnosing the truck that day. Since then, he taped up all the burnt wires and replace the alternator with a reman unit. But it still has a short to ground somewhere when he hooks up the battery cables.
I guess one thing I need is a wiring diagram for this circuit and of course any ideas on what circuit is likely to have a short to ground after having the jumper cables connected in reverse polarity.
I have not started trying to diagnose this yet but I'm about to get started now. I'll post any details I find.
Thanks for any help!
Mike
Old 07-30-2011, 12:17 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Mike, don't know where to even begin except to say a lot of damage may have been done that you will just have to work out one at a time.
The EEC may have been burnt and it could just keep going on and on.
Once a battery has been flattend like that it damages the plates so much that often the battery will never recover to full usefullness.
Also the diodes in the alternator will conduct and over heat.
Some one has to pay attention next time.
Lucky there was not a big bonn fire out of it and lose two vehichles.
Good luck.
Old 07-30-2011, 04:54 AM
Quote:
Lucky there was not a big bonn fire out of it and lose two vehichles..
That's what I told him. And the vehicles were right next to his house too. And he lives 17 miles from the nearest fire dept, so it could even have burned his house down.
Old 07-30-2011, 09:20 AM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Check the voltage on the truck's battery. Pay special attention to the polarity markings on the battery terminals and the ones on your meter. It's very possible to recharge a dead battery the wrong way, and then it's polarity is permanently reversed.
They have this problem on electric vehicles sometimes, where you have a whole bunch of batteries in series. If one has a problem and goes dead, the current passing through it from the other batteries will reverse it's polarity.
Old 07-30-2011, 10:18 AM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Quote:
Never thought about that! I have seen this happen on emergency lighting battery banks though! You have to wonder how many repair guys know about that kind of trouble!
Old 08-02-2011, 01:22 AM
By the time I got a chance to work on it he already had someone tape up all the burned wires and install a new alternator. But it still acted like a dead short when the battery was connected. I tested battery polarity (which was still correct) but after charging the battery it load tested bad. I installed a known good battery and the starter engaged when I connected the cables. So I replaced the starter solenoid and it fired up and ran fine. Alternator is charging too. So he's happy for now but I told him not to count on those taped up wires for long. His income is a limited disability check so he said he would pay me to get all the wires replaced when he can afford it.
Anyway, till then, thanks for the help everyone!
Old 08-02-2011, 04:08 AM
kedwinh's Avatar
kedwinh kedwinh is offline
kedwinh is gaining momentum as a positive member of FTE.
Your REAL lucky! I've seen batteries explode from that and spray acid all over the place.
Old 08-02-2011, 05:09 AM
Quote:
Yep, I've seen that too and learned to keep my face out of the way when connecting or disconnecting a battery, anytime. Thanks!
Batteries & Cables Replaced VindexInjuriae 1999 - 2003 7.3L Power Stroke Diesel 1 08-14-2014 06:43 PM
1994 Ranger Splash Clearacrosstexas Ranger & B-Series 3 02-09-2014 07:03 AM
Starting system failure? Ironoutlaw2010 1987 - 1996 F150 & Larger F-Series Trucks 1 11-18-2013 08:15 PM
85 6.9 slow cranking, acting like dead batteries surfaccing Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 04-22-2013 09:46 PM
OT Neighbor hooked up jumper cables backwards tdpower 1999 - 2003 7.3L Power Stroke Diesel 14 01-28-2012 02:32 PM
Tags
1997, backward, backwards, battery, cable, cables, escape, explorer, ford, ground, hook, hooking, jumper, shorts, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
