Intake upgrade ??? exhaust upgrade??
What's a good carb intake for my hauling truck? 86 f-250 with a 351w. Looking to get a cheap set of iron gt40 heads and have an edelbrock 1406 carb already. I'm not looking for something extravagant just looking for more performance. Are there any direct fit headers for our trucks? Or do we need custom after the headers? Thanks
JEG's sells several headers for our trucks, and I believe 80s Mustang shorty headers will fit too (maybe even to the factory Y-pipe, though I'm not certain). LMC sells exhaust kits for our trucks as well, but I'm not sure if you'd save money going that route or just taking your truck to a shop and having them do something custom.
As far as the intake, I'm not sure, I'll have to pass that question off to someone else...lol
There are no headers I know of to fit our trucks where the exhaust pipes will not need to be modified. That's the real problem with headers on these trucks. They bring the exhaust down way low, and sometimes in the way of the tranny pan and crossmember. You then have to decide how to route it after that, and you will have to do it yourself or take it to a shop.
You will want a very conservative intake design. The bottom of the line performer or another low-rise small runner diameter intake. That will give you good low end which is what a truck needs that is used as a truck.
Dave's right - as always. I recommend the Edelbrock Performer, which is designed for low RPM. Not the Performer RPM, which is designed for a bit higher RPM - which is a shame since a guy keeps adverting one on craigslist here for not much money. And, I've read that the Weiand Stealth is good for low end torque as well.
On the other hand, the Ford cast iron 4v intake is supposed to be a decent manifold. Not as good as those above but should be less expensive if you can find one in the jy.
460jared96
21
12-02-2015 12:45 AM
80' ford man55
08-24-2011 04:57 PM
mustang_gt_350
15
07-30-2011 03:48 PM
