what he said they are pretty much the same motor both are interchangable but the injectors plenums drivers manifold turbo injectors valvecover gasket the alternator and ac brackets and a few other things are different but the block and heads are the same
The cam is different the SD cam does not have the lobe gh run a manual fuel pump
Correct, but the cam has the same cut on it... It is no different. I am running the OBS cam in my truck...
Originally Posted by wmiller
X2 on cam. Also after i think 01 they went to different rods that are lighter and wont hold up to high horsepower
in 2001 they went to Powdered Metal Rods, they are not lighter, just made a different way. They are fine to 400-450hp, beyond that Forged are a better option.
But again, they are the same motor... Swapping a 2003 7.3 into an OBS is nothing special, just like swapping a 1996 7.3 into a 2003...
