Superduty with first gen powerstroke? - Ford Truck Enthusiasts Forums
Old 07-29-2011, 09:54 PM
1982_f150's Avatar
1982_f150 1982_f150 is offline
1982_f150 is starting off with a positive reputation.
has anyone ever done this swap. i think it be kinda cool
Old 07-30-2011, 06:16 AM
bad12jr's Avatar
bad12jr bad12jr is offline
bad12jr is gaining momentum as a positive member of FTE.bad12jr is gaining momentum as a positive member of FTE.
Basically the same motor. Differences are injectors turbo and hpop. Otherwise the same internals and such performance wise.
Old 07-30-2011, 08:07 AM
rodneywar's Avatar
rodneywar rodneywar is offline
rodneywar has a good reputation on FTE.rodneywar has a good reputation on FTE.
what he said they are pretty much the same motor both are interchangable but the injectors plenums drivers manifold turbo injectors valvecover gasket the alternator and ac brackets and a few other things are different but the block and heads are the same
Old 07-30-2011, 10:20 AM
CSIPSD's Avatar
CSIPSD CSIPSD is offline
CSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to behold
Not sure what your asking?
I have a 97 motor in my truck right now...
Old 07-30-2011, 11:02 AM
1982_f150's Avatar
A 95 to 97 engine in a superduty or a 1999 to 2003 engine in an OBS. Just thought it be an interesting swap, old with the new.
Old 07-30-2011, 11:34 AM
CSIPSD's Avatar
Its the same motor... Remove the injectors, turbo and HPOP and a 95-97 7.3 is the exact same as a 99 to 2003 7.3.
Old 07-30-2011, 11:57 AM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
The cam is different the SD cam does not have the lobe gh run a manual fuel pump
Old 07-30-2011, 12:53 PM
wmiller's Avatar
wmiller wmiller is offline
wmiller is starting off with a positive reputation.
X2 on cam. Also after i think 01 they went to different rods that are lighter and wont hold up to high horsepower
Old 07-30-2011, 01:08 PM
CSIPSD's Avatar
Quote:
Correct, but the cam has the same cut on it... It is no different. I am running the OBS cam in my truck...
Quote:
in 2001 they went to Powdered Metal Rods, they are not lighter, just made a different way. They are fine to 400-450hp, beyond that Forged are a better option.
But again, they are the same motor... Swapping a 2003 7.3 into an OBS is nothing special, just like swapping a 1996 7.3 into a 2003...
Old 07-30-2011, 04:10 PM
fordpride's Avatar
I guess what I was trying to say is to run the 99-03 7.3 in a OBS you would have to change the cam or elec fuel
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 12:40 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 10:21 PM
Tags
2001, 73, cam, duty, engine, engines, ford, forged, gen, lift, lobe, obs, powerstroke, pump, rod, super, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
