Ladder bar brackets are on
06-18-2011, 06:48 PM
on
06-18-2011, 07:39 PM
06-18-2011, 08:41 PM
Looks good. I take it you're building the bars in place or using an adjustable heim joint on them since you're mounting brackets first?
06-18-2011, 09:07 PM
on
Im going to use top link end from a 3 point hitch so it will be adjustable if need be. I thought about making more
06-18-2011, 10:38 PM
06-19-2011, 08:26 PM
on
I'm lost! What are they for?
06-19-2011, 08:31 PM
on
im assuming ladder bars are traction bars
06-19-2011, 08:35 PM
on
That what I was thinking but not sure!
06-20-2011, 09:49 PM
on
They will go between the axle and brackets to help take out the nasty spring wrap and wheel hop
06-20-2011, 09:54 PM
bracket looks good. you are gonna put a shackle in there right? if not your gonna get a ton of pressure pushing it forward when you compress your suspension and a lot of pull when you extend it. creates a lot of binding.
06-20-2011, 10:00 PM
on
i will be building a set of these also. looks good
07-30-2011, 12:44 PM
on
No shackel on it but i did make them long (almost 7 1/2') so they should still allow so articulation.
Heres the truck with them on. I'll try to get better pictures later
facusessa
39
07-10-2013 09:34 AM
im2tall33
107
04-29-2012 01:58 PM
Krisx125
12-22-2011 05:41 PM
Jexes23
06-18-2011 11:42 PM
superbean
33
05-06-2011 02:10 PM
04 ,
12 ,
2004 ,
2011 ,
bar ,
bars ,
bracket ,
brackets ,
build ,
f250 ,
f350 ,
ladder ,
lift ,
setup ,
shackles ,
truck
