f-600 370 automatic transmission?
Good evening gentlemen, I understand that some kind of automatics were available in 80's 2 tons, I have an excellent 370 I pulled from a 81 or so 600, and would be thrilled to install it in my 77 250, what would that take, besides a flex plate for an automatic with the big crank bolt pattern? Thanks, Johnny
The A/T is a Transmatic, there are three versions used with 370/429's, two different flexplates.
D9HZ6375G .. Flywheel (flexplate) / Marked D9HT-BC / Use with Transmatic models MT643 T/M & MT650 T/M.
E5HZ6375A .. Flywheel (flexplate) / Marked E5HT-AA / Use with Transmatic model MT540 T/M.
Will the huge Transmatic case fit under the floorpan of a F100/350?
Looks like I'm doing something very similar and I'm trying to figure out which flywheel to use. I have a 370 that had a manual 4 speed on it. I have a C6 from a 460 that I'm going to put on my 370.
I pulled off the manual transmission from my 370 and the flywheel on the 370 is weighted I believe.
Hotwrench suggested using an unweighted flywheel. Can anyone explain this to me? I know the manual transmissions use a different flywheel. I can get either a weighted or un-weighted flywheel that will fit, just need to know which one.
Thanks Broncoman, that's kinda what my thinking was. I have an old N series that someone put a weighted flywheel on a 330 that was supposed to have a non-weighted. It shook pretty bad until I dropped the dust cover and ground the weight off the flywheel with a hand held grinder.
With the 370, I just wasn't sure if there was some difference in going from the manual to an automatic transmission that would make it necessary to switch from weighted to non-weighted.
JFoshee
11-16-2014 06:26 PM
ddsprint
06-27-2008 07:44 AM
neilf600
05-06-2005 07:44 PM
BigBlockBill460
01-17-2004 06:59 PM
gabraham
06-16-2003 06:41 PM
