Where to buy a rear drive shaft - Ford Truck Enthusiasts Forums
Old 07-29-2011, 12:09 PM
rickscott2 rickscott2 is offline
rickscott2 is starting off with a positive reputation.
My rear drive shaft broke, and I can't find anyone that sell them. The dealer told me it is an obsolete part. Anyone know where I can buy one?
Old 07-29-2011, 12:11 PM
Sorry, forgot to mention the details of the truck. 1992 F250 long wheel base 2wd WB155
Old 07-29-2011, 01:12 PM
Phy's Avatar
Phy Phy is offline
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
A junk yard is probably your best bet, or a driveline shop...
Old 07-29-2011, 01:19 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
I think rockauto.com sells them or try drivetrainspecialists.com for one.
However as Phy says junk yard is probably going to be the cheapest (if you can find the right WB one).
Old 07-29-2011, 02:00 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Where are you located? I might have one thats fits.
Junkyards will be decently priced, just becareful thats its not messed up from the forklifts! One I bought when I was doing my 4x4 conversion ended up being dented and vibrated like a *******.
What do you mean by broke?
Old 07-29-2011, 02:43 PM
greywynd greywynd is offline
greywynd is starting off with a positive reputation.
Forget which wb is which. This is an F250, so either reg cab or supercab, in 2wd. I don't have that length here.
Besides, there should be a driveline shop somewhere near you that can repair it, there's a whop here that has new tubes, and new yokes, and can pretty well make any combination that one wants.
Old 07-29-2011, 02:46 PM
Phy's Avatar
Phy Phy is offline
155" is a supercab.
Old 07-29-2011, 04:10 PM
I am in Central Texas. The circle where the u-joint fits in is broken
Old 07-29-2011, 06:09 PM
Otahyoni's Avatar
Otahyoni Otahyoni is offline
Otahyoni has a good reputation on FTE.Otahyoni has a good reputation on FTE.
Sounds like he broke one of the yokes...
Look for a driveline shop near you. They can replace the broke yoke and rebalance the shaft.
Old 07-29-2011, 08:22 PM
Yeah I broke one of the yokes. The closest shop I've been able to find is in Austin, which is about an hour away.
Old 07-29-2011, 11:57 PM
Country_boy_2007's Avatar
Country_boy_2007 Country_boy_2007 is offline
Country_boy_2007 is gaining momentum as a positive member of FTE.
a good shop will beable to fix the yoke and balence it for less that youll have in a new drive shaft
Old 07-30-2011, 01:53 AM
jdimassi's Avatar
jdimassi jdimassi is offline
jdimassi is starting off with a positive reputation.
Car-Part.com--Used Auto Parts Market will give you an idea who local has a shaft i use the site all the time also a good tool to check prices yards are getting for stuff i hope this helped let me knowww
Old 07-30-2011, 06:07 AM
Otahyoni's Avatar
Quote:
That is a good site. I've used it to find a few parts i couldn't get in town...
Old 08-03-2011, 08:08 PM
Thanks everyone for your advice, I found a drive shaft using the website listed above. Truck is running like a champ again. Thanks again.
Old 06-19-2014, 11:51 AM
Remydv Remydv is offline
Remydv is starting off with a positive reputation.
Dorman offers now a line of new fully assembled drive shaft
Check this out
Dorman Products
Rear drive shaft substitute? joshcha2 Bronco II 3 07-16-2015 04:57 PM
I need help with Transfer case sensores Omarzero Explorer, Sport Trac, Mountaineer & Aviator 13 04-22-2015 09:08 AM
Rear Drive Shaft hillbillywilly 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-12-2013 12:10 AM
Need drive shaft Help CdnSoldier Canadian National Chapter 1 04-19-2009 12:05 AM
rear drive shaft gone casanovaceo 1978 - 1996 Big Bronco 4 09-04-2004 08:09 AM
Tags
1990, 1997, 2004, cost, drive, driveshaft, f150, f350, ford, indiana, ranger, rear, replace, shaft, shafts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
