First I would like to thank you guys for all that you do! You guys are THE best resource I have ever found for my truck!
Second, my little problem... This has been going on for a while but keeps getting worse... every time I take off from a start or so it seems the turbo starts to spool I get black smoke out the tailpipe and it seems like a ton of turbo lag... I also have noticed if the turbo starts kicking in on a hill there is some smoke... It seems like when the turbo hits 8-10 psi it clears up and runs fine w/ no smoke...
Could this be a FICM or Intercooler boots?
Truck is an 06 bone stock except for straight pipe and coolant filter w/ 108k on it...
when i bought mine i noticed the turbo lag from take off....so we drove three other 6.0's and they seemed to do the same... is this what you experience w your 6.0...
I roll into the throttle from a stop and after about 20-30 feet the
turbo seems to have spooled up and it'll take off if I push harder on the
go pedal. It seems about 2k RPM is where the "wow" kicks in.
If I just floor it from a stop, it won't go anywhere and it'll put out
black smoke - unburned fuel. I did replace the air filter and it didn't
change.
that seems very slow, 20 - 30 feet... with my street tune mine kicks in at ~3 secons, but never 5sec or more (under 3,000ft) for wot or a hard pull. on lighter throttle I do not have lag... 20-30ft just does not seem right.
Check for exhaust leaks between the turbo and the exhaust manifolds. Mine does the same and I discovered my Y pipe has a leak.
That would be my first inclination without knowing anything else. High EGTs would be a clear indicator if the OP has gauges. A leak would also get progressively worse as well.
Hey guys, I just went and had it scanned and it came back clear... Now this leak that you are talking about in the Y pipe... Where is the Y pipe and how is the best way to check for a leak? Thank you for all you guys input!!! I would love to get this fixed!
