remove dings in stainless
Dale i just found it on the Eastwood site under hammers and dollys It a special thin anvil a hammer and a how to fix trim booklet, and i think its $48
If you need to use a hammer, try a small tack hammer. Tap gently on a block of wood rather than steel so you don't thin and stretch the metal. For real small dents, you might try pushing them out with an awl or a carefully rounded screwdriver (from years of misuse). I've seen a guy use one of the screen door tools that looks like a pizza cutter to roll the dent out, also. Just go slow and check your progress frequently.
You need to make up some specialty tools, an aul out of an old broken scew driver and push the dents out while on a block, I also have a teflon piece that looks like a flat blade screw driver that works well. A small rounded hammer (miniature) for bigger ones then take a file to the high spots very carefully and then polish and buff. Very time consuming but they will come out.
chaosinc
05-18-2012 12:12 PM
horsepuller
Garage & Workshop
02-03-2008 03:04 AM
