chugging at 50+mph - Ford Truck Enthusiasts Forums
chugging at 50+mph
Old 07-28-2011, 10:46 PM
devils toy devils toy is offline
devils toy is starting off with a positive reputation.
chugging at 50+mph
2004 F350 6ltr runs strong, excelerates strong but when getting up to 50 + truck starts to chug pretty bad. If I let off of the gas it seems to stop, if I excelerate past 60 it seems to stop. I am leaning towards the transmission or possibly the converter going bad. Anyone else have this happen?
**new FICM and 4 injectors have already been replaced.
Old 07-28-2011, 10:48 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
Old 07-28-2011, 11:58 PM
Unrealo4's Avatar
Unrealo4 Unrealo4 is offline
Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.
Sounds like a bad injector. That is exactly what mine did when my #4 died 2 weeks after being replaced. New injectors can fail.
Old 07-29-2011, 12:12 AM
You had the chugging at cruising speeds? If i stomp on the pedal it ran like a son of a biscuit and at over 70 it seemed fine.
Old 07-29-2011, 12:30 AM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
have you scaned it for codes
Old 07-29-2011, 12:39 AM
no codes stored. last code retrieved was a iat sensor gone bad that was a month ago, no mods. Only thing done is 4 new injectors, egr, 2nd icp and ficm
Old 07-29-2011, 07:34 AM
Benchwrench's Avatar
Benchwrench Benchwrench is offline
Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.
possibly sticky turbo vane actuation.
is the programming stock or are you running aftermarket tuning?
Old 07-29-2011, 11:59 AM
BLADE35's Avatar
great advise!!
Old 07-29-2011, 12:02 PM
mblanken881 mblanken881 is offline
mblanken881 is starting off with a positive reputation.
is the motor chugging or is the truck kind of vibrating or lurching? mine does the same kind of thing right at 50 MPH but mine is a bad carrier bearing.
Old 07-29-2011, 05:17 PM
The programming is stock for now. I thought about the turbo to and start to play with it. I disable the vgt. Still had the same problem. @mblanken it is kind of hard to explain. I use the term chugging cause that is how the misses describes it.It is almost like it is bucking. I have had a carrier bearing go. Does feel like that.
I was leaning towards tranny thinking maybe the converter is not locking up or slipping some how.
Old 07-29-2011, 09:09 PM
pile_53574 pile_53574 is offline
pile_53574 is starting off with a positive reputation.
I would also suggest sticky turbo. Just had mine cleaned and now runs better than new!! I had underboost codes and chugging at slower speeds. Try cleaning the turbo an see wat happens.
Old 07-29-2011, 09:58 PM
428fordmoco 428fordmoco is offline
428fordmoco is starting off with a positive reputation.
chugging at 50+mph
I had the same problem on my 2004 F250 CC, after I ran the codes I found that #7cyd had a continuity imbalance . I replaced the #7 injecter and solved the problem. Good luck.
Old 08-10-2011, 10:06 PM
Just wanted to thank everyone for their help. It turned out to be number 1 injector. 2 hours later I was hauling ***. Thanks again. Now to install my SCT livewire. Cant wait to see how that works with my 39 foot fifth wheel.
Old 08-10-2011, 10:12 PM
BLADE35's Avatar
looks like you nailed it Jim
thanks for coming back and posting the out come this will help others
Old 08-11-2011, 01:12 AM
Unrealo4's Avatar
Haha bucking our chugging at 50 mph. Seems to be injector related 9 times out of 10 in my limited experience.
2005 expedition transmission problem Jinskeep3983 1997-2006 Expedition & Navigator 4 09-06-2013 11:58 PM
Escape knocking 2005 reboswon Escape & Escape Hybrid 6 01-25-2011 07:26 AM
suddenly quieter? Edkajo 1999 - 2003 7.3L Power Stroke Diesel 11 05-30-2010 09:46 AM
Strange Whistle, (possible intake leak) 81-F-150-Explorer Ford Inline Six, 200, 250, 4.9L / 300 8 06-10-2009 10:10 PM
v10 surging halvy Modular V10 (6.8l) 10 07-30-2008 09:57 PM
Tags
2007, 50, 60, 60l, 67, 70mph, chugging, diesel, f150, f250, f350, ford, mph, stumble, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
