2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 Limited Edition tail light lenses???
Old 01-04-2011, 02:05 PM
JMKiser's Avatar
JMKiser
JMKiser is offline
I have a 2007 Limited Edition Expedition that has a three element tail light cover. The bottom red light is the stop, turn signal, emergency flasher, parking and running light. The middle light is the white back up light. The third or top red light is my question. The lamp never illuminates under and lighting condition. The bulb (that looks as if it’s never been light up) is a 921.
I called my local Ford dealers and they can’t seem to come up with an answer as to what the light is for. The Ford parts department shows only a two position light cover, red and white. I have a 2007-2008 Ford DVD and there is no reference to it either, can someone please shed some light on that this lamp is for?
Kind regards,
John from Alaska….
Old 01-05-2011, 07:28 AM
Harley Guy's Avatar
Harley Guy
Harley Guy is offline
I'm stumped - went out to look at mine because of this post and nothing appears to use the upper bulb... Brake lights, tail lights, emergency flashers, and turn signals all use the lower bulbs. The only thing I can think of is that maybe Ford didn't use different tail lights for export versions. European requirements are for red fog lamps in the rear on the left side. All of my Volvos have this...
B/R,
RP
Old 01-05-2011, 11:20 AM
JMKiser's Avatar
JMKiser
JMKiser is offline
Thanks for the reply man, anyway I was traveling around yesterday evening and followed two Expeditions with the same light housing. Neither of them illuminated while they were driving.
Perhaps this is for Fire, Police and/or Rescue vehicles only in the U.S.
It sure is odd though for them not to work. Seems like such a waste of engineering talent, what’s so hard about wiring it from the factory. Perhaps this fall when it warms up around here I’ll look into re-wiring them so that they come on as ruining lights.
Best regards,
John from Alaska….
Old 01-05-2011, 02:21 PM
gddyup's Avatar
gddyup
gddyup is offline
I have an 07 and never even thought of what those upper portions were for. I didn't even realize they had bulbs in them. If I can get by the PD or catch up with the Sargent on duty tomorrow I will see if theirs' is hooked up in any way. Their supervisor squad is an 07 Expy so I'll take a peek if I have a chance and see if they are used in the LEO/FD role.
Old 01-05-2011, 07:01 PM
chuck s's Avatar
chuck s
chuck s is offline
Color coded wiring no doubt routes to one of the fuse/relay boxes. No doubt to an empty socket.
European rear fog lights are usually very low to the ground, not the highest bulb of the array.
-- Chuck
Old 01-05-2011, 08:29 PM
JMKiser's Avatar
JMKiser
JMKiser is offline
Okay good, so I’m not crazy then? Thanks for checking everybody and please let me know what you find out.
John
Old 01-23-2011, 05:55 AM
Harley Guy's Avatar
Harley Guy
Anyone ever figure this one out? Guess I'll have to break out the wiring diagrams and try to figure it out. My OCD won't let it be...
B/R,
RP
Old 01-26-2011, 01:51 AM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
Ford does that weird crap. My Mustang had a similar setup for the innermost bulb on either side. I re-wired it so that the bulb lights up with the outer 2 and the tails sequence when the blinkers are on.
I wouldn't worry about that. It might even be a Canada thing. Kind of how Canadian spec Fords all come with Foglights automatically, but we have to buy the module if you want DRL inside the US.
Old 07-13-2011, 09:41 PM
hjsimpson's Avatar
hjsimpson
hjsimpson is offline
Anyone figure this out???
Old 07-14-2011, 09:47 AM
SickPup404's Avatar
SickPup404
SickPup404 is offline
Checked mine (2007 Expedition EL Limited, final assy @ Michigan Truck plant, 11/22/2006), and the light has only the b/u and brake/tail light. The upper section is just a red reflector. There IS a small hole taped over w/ blue tape, but I don't think it's big enough for any bulbs - only about 1/4" dia.
Old 07-15-2011, 10:31 AM
TCAS007's Avatar
TCAS007
TCAS007 is offline
same here - reflector... but it would be great to have an additional bulb there.
Old 07-30-2011, 10:31 PM
TCAS007's Avatar
TCAS007
TCAS007 is offline
do the navigator ones fit? they would have 3 lenses too and it would look great.
eddieniner
2015 + Expedition & Navigator
06-05-2016 12:39 AM
the_auto_tech
2009 - 2014 F150
19
08-09-2015 06:43 PM
cherrybomb37
10-08-2014 10:16 PM
whalebus2112
09-07-2014 06:45 PM
johnson2007
17
10-03-2011 08:24 AM
Quick Reply: 2007 Limited Edition tail light lenses???
