Rear end ID... - Ford Truck Enthusiasts Forums
Rear end ID...
Old 07-28-2011, 09:55 AM
R.England R.England is offline
R.England is starting off with a positive reputation.
Rear end ID...
I have a 1983 ford bronco 4x4 can anyone tell me what size rear end came in that year. i mean like a 9 in. or what i know it cant be an 8.8 thats what my step dad has in his 95 stang. so could someone let me know please thanks...
Old 07-28-2011, 10:04 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is online now
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
Quote:
A quick way to tell:
If the bolts to open up the differential are on the front (the side with the driveshaft coming in), it's a 9".
If the bolts and access plate are on the rear towards the tailgate, it's an 8.8".
They started using the 8.8 around 82 - 84 (can't remember exactly, my 84 has an 8.8"), so it's possible you could have either.
Old 07-28-2011, 10:21 AM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Hopefully your's look like one of the ones pictured, if not post a picture, maybe a previous owner swapped in something odd.
Old 11-17-2012, 06:46 PM
Kayne Kayne is offline
Kayne is starting off with a positive reputation.
I actually have a 83 ford bronco with a 8.5 rear end. the research shows it has the unique pinion flange that you cant use 8.8 parts. So I need to know what vehicles can i steel the axle out of that will bolt right up. The rear end i have now has missing teeth and no parts avaliable. So im looking for a axle i can refresh and bolt in. thanks in advance guys
Old 11-17-2012, 07:26 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
The only 8.5 Ford differential was produced for a very limited time. I only know of its use in 1979-82 on the first of the "downsized" Crown Vic's. It DOES use the same carrier and gear sets as the 8.8 though. The Bronco was only equipped from the factory with the 9' or the 8.8. So, if you truly have an 8.5 which is a WER-E differential, then someone swapped it in. The gears and carriers for an 8.8 will swap in though. If the pinion flange is different, you should be able to swap to the pinion flange from an 8.8 to make everything work.
Old 11-17-2012, 07:51 PM
The axle tag is WDR-D. According to everything ive found this came in the 83 bronco, 83 F100 and F150 with a 3.55 ratio, The axle is identical to a 8.8 every where but the pinion which is a smaller diamiter. Cant get parts for it so i need to know what years and vehicle types i can get a axle out of to bolt straight up to the 83 bronco. this way also if it ever craps again i can just get the parts needed. Thanks again for the info and help guys.
Old 11-17-2012, 10:43 PM
CS79bronco CS79bronco is offline
CS79bronco is gaining momentum as a positive member of FTE.
You should be able to find 9" rears pretty easily, with 3.55 gears as they seem to be the most common in Broncos. 78 & up thru early 80s Broncos & 73? thru early 80s F150 should bolt right in. An 8.8 would work also, but the 9" is considered better by most guys. Only experience I've had with 8.8 was my son's 92 Bronco. It started making clunking noises, then locked up a few days later. We replaced it with another 8.8 from the JY.
Old 11-17-2012, 11:52 PM
Quote:
Dude this is what i was trying to figure out. Thank you so much.I would like it if anyone can confirm that the year ranges will fit. That be extra awesome. Im going to start cruzing the JY's and Craigs list now. Thanks again guys.
Edit. Does the more splines mean stronger axles??
Old 11-18-2012, 12:09 AM
Edgethis's Avatar
Those year ranges sound good to me. More splines generally means stronger. But i wouldn't worry too much about them.
Old 11-20-2012, 08:56 PM
IIRC, the Bronco 9" came with 35 spline axles & F150 with 31 splines.
triangulated 4 link question kevintoupin 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 09-14-2016 10:17 PM
What is the width of a Crown Victoria 8.8 rear end? Daddyo's garage 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 05-10-2014 10:01 PM
Rear end Question 1999stroke 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-29-2014 08:23 AM
what year rear ends will fit in my truck? dakota-boy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 02-04-2011 11:39 PM
Ford 8.8 Rear Axle Assembly - Differences cher96 Explorer, Sport Trac, Mountaineer & Aviator 7 06-08-2009 01:01 PM
Tags
1983, 1995, 78, bronco, diesel, dimensions, end, f150, ford, id, number, ranger, rear, rearend, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
